426 hemi std bore? #958797
03/26/11 12:14 AM
03/26/11 12:14 AM
central new york
pettyblue440 Offline OP
central new york
what is the std bore size of a 426 hemi? thanks, jon
Re: 426 hemi std bore? [Re: pettyblue440] #958798
03/26/11 12:15 AM
03/26/11 12:15 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
4.250
Re: 426 hemi std bore? [Re: 1_WILD_RT] #958799
03/26/11 12:16 AM
03/26/11 12:16 AM
central new york
central new york
that was fast. thank you!
Re: 426 hemi std bore? [Re: pettyblue440] #958800
03/26/11 12:24 AM
03/26/11 12:24 AM
central new york
central new york
may as well hijack my own thread. how much of an overbore can these blocks take? Is it like a wedge being limited to .030 or .060, or can it go more after being checked out?
Re: 426 hemi std bore? [Re: pettyblue440] #958801
03/26/11 12:48 AM
03/26/11 12:48 AM
All blocks should be thoroughly sonic tested before boring, stuff happens when you don't know. Are you talking about a old OEM Hemi block, a new Mopar replacement block or what block are you asking about?
Re: 426 hemi std bore? [Re: Cab_Burge] #958802
03/26/11 01:09 AM
03/26/11 01:09 AM
central new york
central new york
it is an oem 66 or 67 I am looking at. It says it has been checked out and the final bore would be 4.380. Any chance the walls are that strong?
Re: 426 hemi std bore? [Re: pettyblue440] #958803
03/26/11 01:14 AM
03/26/11 01:14 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
4.38 or 4.28... 4.28 is .030 over & while it should be sonic checked it's probably fine... 4.38 is .130 over & that isn't gonna work....
Re: 426 hemi std bore? [Re: 1_WILD_RT] #958804
03/26/11 03:28 AM
03/26/11 03:28 AM
I have sonic tested a lot of Mopar blocks, old and new, including some of the new (pre World brand blocks) replacement blocks from Mopar, not the newer World blocks as all of the cast iron World blocks are thick wall siameze bores. I don't think any of the old OEM ones will bore safely beyond 4.320 that I tested Of course it depends on how much cylinder wall thickness you want left after the bore I like at least .150 minimum on the major thrust side of the cylinders on a mild street performance motor
