fuel gauge and sending unit install #958696
03/25/11 10:18 PM
03/25/11 10:18 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
Fuel gauge and sending unit on my Dodge chassis Winnebago has died, I am going to buy a new auxillary gauge and sending unit to replace them, has anyone rewired in a new set-up like this to anything before and if so is there anything else I have to buy to make it work? I know the gauge and sender ohm's have to match but do you have to also buy some sort of resistor or regulator for the 12volt??
Re: fuel gauge and sending unit install [Re: dartman366] #958697
03/27/11 12:03 AM
03/27/11 12:03 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
really now, so no one has ever done this.
Re: fuel gauge and sending unit install [Re: dartman366] #958698
03/27/11 12:05 AM
03/27/11 12:05 AM
N
NITROUSN Offline
NITROUSN  Offline
N
As long as the units ohm reading are the same you just need a switch to toggle between tanks.
Re: fuel gauge and sending unit install [Re: NITROUSN] #958699
03/27/11 12:11 AM
03/27/11 12:11 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
thank's, I think the guy before me tied the two tank's together so I may have to get another sender and seperate them like they are supposed to be, but that is not a priority right now.
Re: fuel gauge and sending unit install [Re: dartman366] #958700
03/27/11 12:15 AM
03/27/11 12:15 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I have a old dodge dual tank electric switching valve if you need it. Might even have the switch.
Re: fuel gauge and sending unit install [Re: NITROUSN] #958701
03/27/11 12:21 AM
03/27/11 12:21 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I will keep that in mind, Thanks
