Who makes a good fuel sending unit? #958591
03/25/11 06:47 PM
03/25/11 06:47 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
The oem one in the Challenger is shot. I see Goodmark and Right Stuff makes em.
Re: Who makes a good fuel sending unit? [Re: A990] #958592
03/25/11 06:57 PM
03/25/11 06:57 PM
California
mickm Offline
mickm  Offline
California
many threads on this board about them. almost none of them seem to work. i have put a couple of hours into messing with mine, and can't get it right. on the bench everything seems perfect. put it in and it's at least 1/4 tank off. almost everyone says that, 1/8 to 1/4 off.
talk to bill at AM HighTechAuto, (a member here), amhightechauto.com. he will know who is making the better ones out there, for whatever that is worth.
Re: Who makes a good fuel sending unit? [Re: mickm] #958593
03/25/11 07:09 PM
03/25/11 07:09 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I suggest sending a decent core to a Instrument Repair shop...
Re: Who makes a good fuel sending unit? [Re: mickm] #958594
03/25/11 07:51 PM
03/25/11 07:51 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Mine I bought last year shows 1/4 tank when it's dead empty, and full at anything over 1/2 a tank.
When I measured it I think it showed 11ohms empty and about 78ohms full which I've been told is close to the factory senders, so I don't know why it's off so far. I was wondering if I could add resistor inline with the ground wire to get it to read closer to correct?
Re: Who makes a good fuel sending unit? [Re: 440newport] #958595
03/25/11 09:21 PM
03/25/11 09:21 PM
California
mickm Offline
mickm  Offline
California
mine goes the other way, shows empty when it has about 1/4 tank, and won't get much over 3/4 when full. seems like it should be easy to adjust, but i have set it so that it matches the factory ohm settings, and have played with adjusting the float, never comes out right.
1_wild_rt has a good point. i'm going to start looking for a used core and see if i can either use it as it is or have someone rebuild it.
Re: Who makes a good fuel sending unit? [Re: mickm] #958596
03/25/11 09:56 PM
03/25/11 09:56 PM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
I have put 2 of them in my 72 cuda and it is still off by 1/4 tank. It will show full when you fill the tank, but as soon as you run out little fuel it drops a lot more than it actually should. What i do now is fill up at about 1/4 tank and always find i have about 1/2 tank instead of 1/4. I just live with it now. Yes, it does have the ground strap.
