I.D. this holley? #958457
03/25/11 01:07 PM
03/25/11 01:07 PM
gregsdart Offline OP
650 cfm(?) 6r4585B
80145 d240. What is the intended use? Good bracket carb for a 318/340?
Re: I.D. this holley? [Re: gregsdart] #958458
03/25/11 02:30 PM
03/25/11 02:30 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
You can call Holley on their toll free number and ask them all the particulars. You can actually talk to a real person.
Re: I.D. this holley? [Re: gregsdart] #958459
03/25/11 06:26 PM
03/25/11 06:26 PM
Locomotion Offline
Locomotion  Offline
I couldn't find a R6585, but I did find a R80145, which is a 600 vacuum secondary carb. Couldn't find the actual part or application, just lots of parts for it.
Holley carb part numbers.
Kinda small for a bracket race application, or even for the street unless you're after fuel mileage. I've run between 650 and 750 carbs on a 360, usually double pumpers. But a vacuum sec. may be easier to tune. But I suppose it could be decent on a 318. How it's tuned is the important part. A secondary metering block would help with jet changes.
Re: I.D. this holley? [Re: gregsdart] #958460
03/25/11 08:59 PM
03/25/11 08:59 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
just last weekend i was looking over a Holley like the one described. it had a "Motorcraft" tag with a number very similar to that one...it may be a Ford part #
