Holley 850 DP or 750 vac sec for........... #958112
03/24/11 10:37 PM
03/24/11 10:37 PM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
my 440. Specs: @ 10 to 1 comp (6200 ft though)
Summit cam 224 @ .050
3500 stall
3.91 gears
Hedman headers 2.5 exhaust
Performer RPM intake
452 heads.
Car is a 64 Dodge @ 3800 lbs.
I'm leaning towards the 750.
britt
Re: Holley 850 DP or 750 vac sec for........... [Re: pwr440] #958113
03/24/11 10:59 PM
03/24/11 10:59 PM
Locomotion Online content
Locomotion  Online Content
I think a 750 will be more streetable and tunable, not to mention better gas mileage! It's usually better to lean on the conservative side.
Re: Holley 850 DP or 750 vac sec for........... [Re: pwr440] #958114
03/24/11 11:01 PM
03/24/11 11:01 PM
Central NC
gch Offline
gch  Offline
Central NC
750 vac secondary would be my choice unless it is a bracket car.
Now if you asked about an 800 DP I think that would be the shiznit.
Re: Holley 850 DP or 750 vac sec for........... [Re: pwr440] #958115
03/24/11 11:08 PM
03/24/11 11:08 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I vote for the 850 dp. I had an 800 DP on a 440 with a 222 @.050 cam 3.23 stock converter, and at over 4200 lbs. It ran better than with my 3310 or 750 AFB.
Re: Holley 850 DP or 750 vac sec for........... [Re: gch] #958116
03/24/11 11:10 PM
03/24/11 11:10 PM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
Thanks. I was thinking about a new 800 THUNDER AVS but I saw these carbs on craig's list for cheaper so I was Thanks.
britt
Re: Holley 850 DP or 750 vac sec for........... [Re: BSB67] #958117
03/24/11 11:22 PM
03/24/11 11:22 PM
Central NC
gch Offline
gch  Offline
Central NC
With the 3.91's and converter I was thinking it could use 800cfm with the smaller diameter throttle bores(same as 750/less than 850)and still have decent part throttle response.
I will agree it is hard to beat a well tuned 750 vac sec on many applications(my 496 barge included).
Re: Holley 850 DP or 750 vac sec for........... [Re: gch] #958118
03/25/11 12:00 AM
03/25/11 12:00 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have run them all, and a variety of engines and my similar engine 10:1 446 with street gears, and a good driver will be getting a 750 3310 vacuum carb.
small hyd cam, well ported 452 heads with 2.14/1.81 valves engine ran low 7's in the 8th mile with a solid cam and more gear and converter.
Re: Holley 850 DP or 750 vac sec for........... [Re: Bob_Coomer] #958119
03/25/11 01:24 AM
03/25/11 01:24 AM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
Thanks for the replies.
britt
Re: Holley 850 DP or 750 vac sec for........... [Re: pwr440] #958120
03/25/11 08:23 AM
03/25/11 08:23 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Really with proper tuning either one would do you just fine.
Re: Holley 850 DP or 750 vac sec for........... [Re: pwr440] #958121
03/25/11 11:14 AM
03/25/11 11:14 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Ideally, you'd get a 750 DP for it. If you have to choose between a 750 vac and 850 dp, it'll run better and be easier to tune w/ the 750 vac. It might not be faster on the track, but you'll like it better on the street.
Re: Holley 850 DP or 750 vac sec for........... [Re: DaytonaTurbo] #958122
03/25/11 02:06 PM
03/25/11 02:06 PM
North Central Indiana
C-Tech Offline
C-Tech  Offline
I would buy wich ever is the better deal, if you want max performance I would buy the 850 for a street car I would use the 750
Kevin
