comp cam roller rocker question #95805
07/27/08 11:11 PM
07/27/08 11:11 PM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
IM running comp cam magnum roller rockers for the first time in my 340 with a high lift cam. Boy do they make some noise. Is this normal???? I can hear them when driving the car. Should they be quiet??? Something in the valve train is makeing noise, a lot more than the stock stamped steel set up. Maybe I need to recheck my valve lash.
Thaks.
Re: comp cam roller rocker question [Re: RonaldV] #95806
07/27/08 11:18 PM
07/27/08 11:18 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
I have them, but got questions for you. How big of a cam and what is the spring pressure. The comps are great rockers but will not hold up against high spring pressure. And yes recheck your lash.
Re: comp cam roller rocker question [Re: 68Fastback] #95807
08/01/08 07:28 AM
08/01/08 07:28 AM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
Cam is comp cam XE 285 HL duration is 241/247 and lift is .545
Springs are behives and are the recommended for this cam, Not sure exactly what pressure they are.
Re: comp cam roller rocker question [Re: RonaldV] #95808
08/01/08 10:38 AM
08/01/08 10:38 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Those rockers should work with that cam. What heads are you running and did you check how the roller contacts the valve tip when opening the valve:
