What ring gap for nitrous SB??? #957998
03/24/11 09:17 PM
03/24/11 09:17 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I am gapping my rings tommorow (sealed power moly rings) and opened the box to find the lousy instruction sheet says nothing about ring gaps. This is an engine that will see N/A almost all the time, with nitrous use every once in a while. Here is the combo...will see 175 shot of spray at most
1991 LA 360 shortblock bone stock rotating assembly (factory dished)...
62cc RHS heads as prepped by Brian at IMM engines for a total compression of (hoping) 9:1-9.5:1
mopar thin 0.024-0.028 compressed thickness head gaskets
Cam is a custom hydraulic roller from Brian at IMM to go along with the RHS heads
230/230 at .50 duraiton
576/576 lift
105LSA with 4-5 degrees advance ground in
Hughes 1.6 ratio rockers and shafts
RPM air gap intake with a 750HP
1-5/8 headers into a 3" exhaust
I have read on the total seal site (Sealed power site sucks! just like their instructions!) that rule of thumb is
bore x 0.006 for shots under 150
bore x 0.008 for shots over 150
min .015" for the oil ring rail
Im also assuming that both compression rings should be gapped exactly the same???
Any info would be greatly appreciated since tommorow ive got a full day in the shop to work on this!
Thanks!
Re: What ring gap for nitrous SB??? [Re: mshred] #957999
03/24/11 09:59 PM
03/24/11 09:59 PM
UK
602heavy Offline
602heavy  Offline
UK
I would'nt be using those moly rings if spraying , any detonation/heat will have the moly blister off the ring , i've had this same issue on a 440 spraying 250 , some will say you can get away with it if the tune good , i would'nt take the chance again , maybe look into the Total Seal advanced profile (AP) with the napier 2nd.
As far as ring end gap i would go .006 x bore for top & 2nd rings.
Re: What ring gap for nitrous SB??? [Re: 602heavy] #958000
03/24/11 10:06 PM
03/24/11 10:06 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Re: What ring gap for nitrous SB??? [Re: fishy340] #958001
03/24/11 10:33 PM
03/24/11 10:33 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
you really would be better off with some Hell Fire top ring. Sealed power sells them.
Bore times .006" would be a good gap for the top ring. I would do the same for the second but many will go .007" times the bore on the second ring.
Re: What ring gap for nitrous SB??? [Re: Leon441] #958002
03/24/11 11:23 PM
03/24/11 11:23 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
thanks for the input guys
Re: What ring gap for nitrous SB??? [Re: mshred] #958003
03/25/11 02:30 PM
03/25/11 02:30 PM
.006 on the top and .007 on the second, retard the timing on the spray and don't run it to rich on the fuel side and those rings should live with 150 HP, not 175 HP
