Hp question #957700
03/24/11 01:58 PM
03/24/11 01:58 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
Is there any way to calculate or ballpark what a engines hp is? I know it will be a ballpark fig without using a dyno but im curious
Re: Hp question [Re: WICKD6PK] #957701
03/24/11 02:09 PM
03/24/11 02:09 PM
gregsdart Offline
gregsdart  Offline
Mph from a drag strip run can get you close. Other than that, it is pretty tough without at least a chassis dyno pull to get a value for hp. Keep in mind that all results need to be corrected to a standard, like a dyno does.
Re: Hp question [Re: WICKD6PK] #957702
03/24/11 02:27 PM
03/24/11 02:27 PM
Some of the on line calculators like Wallace racing have a HP formula, plug in the answer for your parts and enjoy. On the MPH and weight you have to remember the converter is not 100% effecient so that can play havoc on the outcome
Re: Hp question [Re: Cab_Burge] #957703
03/24/11 08:55 PM
03/24/11 08:55 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
weight and mph will get right in the ballpark of what its making
Re: Hp question [Re: fishy340] #957704
03/24/11 10:44 PM
03/24/11 10:44 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
Well there is no dragway close so I dont have a qtr mile time its a b body maybe if I Ppposted my combo somebody could estimate it?
Re: Hp question [Re: WICKD6PK] #957705
03/25/11 12:48 AM
03/25/11 12:48 AM
Google Wallace racing and use thier on line calculator for HP
