automatic trans problem #957640
03/24/11 11:32 AM
03/24/11 11:32 AM
Dayton, OH
1980volare Offline OP
My man card has just been revoked.
Dayton, OH
just installed my new engine and transmission. now the problems. in netural it will rev, but if i rev it up to like 2000 it will lurch forward, and also in reverse sometimes the car will stop,(almost like its put into park. im using a b&m quicksilver shifter that work flawlessly with my old setup. if i shift manually 1st gear works, second revs to 3000 and tries to accelerate, and in drive it seems to go 1st then seems to skip 2nd and hits 3rd.
was told the transmission worked fine(but we all know how that goes)
havent changed the filter could that effect it?
any suggestions?
Re: automatic trans problem [Re: 1980volare] #957641
03/24/11 11:37 AM
03/24/11 11:37 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
Sounds like the shifter is out-of adjustment
Re: automatic trans problem [Re: BeEtLeJuIcE !] #957642
03/24/11 11:42 AM
03/24/11 11:42 AM
Dayton, OH
Dayton, OH
disconnected the linkage and put it in neutral by hand. does the same thing.
Re: automatic trans problem [Re: 1980volare] #957643
03/24/11 11:50 AM
03/24/11 11:50 AM
Florida STAYcation
Florida STAYcation
Do you have solid valve-body shift-lever detent ?
Re: automatic trans problem [Re: BeEtLeJuIcE !] #957644
03/24/11 11:53 AM
03/24/11 11:53 AM
Dayton, OH
Dayton, OH
not sure .not even sure what that is. care to elaborate? as far as i know its a stock 904
Re: automatic trans problem [Re: 1980volare] #957645
03/24/11 12:01 PM
03/24/11 12:01 PM
Florida STAYcation
Florida STAYcation
With the shift cable off .... can you feel the shift lever solidly going into "gear" ?
Re: automatic trans problem [Re: BeEtLeJuIcE !] #957646
03/24/11 12:06 PM
03/24/11 12:06 PM
Dayton, OH
Dayton, OH
yes i can. could this be a od tranny and not like the 3 speed shifter?
Re: automatic trans problem [Re: 1980volare] #957647
03/24/11 12:17 PM
03/24/11 12:17 PM
Florida STAYcation
Florida STAYcation
what year did this person say the trans was ?
It is beginning to sound like your FIRST suggestion ...
was told the transmission worked fine(but we all know how that goes) ....
Re: automatic trans problem [Re: BeEtLeJuIcE !] #957648
03/24/11 12:20 PM
03/24/11 12:20 PM
Dayton, OH
Dayton, OH
came out of a 79 volare roadrunner,318.
Re: automatic trans problem [Re: 1980volare] #957649
03/24/11 12:23 PM
03/24/11 12:23 PM
Florida STAYcation
Florida STAYcation
It could be a LU converter but not a OD. I would say pull the pan and check for junk in the pan and then see if the valve body is bolted-up tight to the case.
Re: automatic trans problem [Re: 1980volare] #957650
03/24/11 03:07 PM
03/24/11 03:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I think you have two separate problems, the creeping forward in Neutral and lockup in Reverse is caused by a rear clutch that's too tight or sticking.
The other problem is in the kickdown band or servo, try a simple adjustment.
