Fuel Pump issue #957361
03/23/11 10:57 PM
03/23/11 10:57 PM
Yuma, Az
ff6849 Offline OP
ff6849  Offline OP
Yuma, Az
I have a M4589 cater fuel pump for a 1973 Barracuda with a 440, the issue I am having is the outlet is facing toward the block perpendicular and there isn't enough clearance for the fuel line. I think I need the style pump with a threaded connection for the outlet with an elbow, would I be correct in my thinking and if so which pump is that. I have a stock 5/16 line at the moment with a mild built 440. I also vaguely remember that there was a metal fuel from the working its way thought back to the carburetor is this also correct and if so where might I find such a line. My first build and my tear down was quite a bit ago and I am having a hard time remembering where everything goes.
Re: Fuel Pump issue [Re: ff6849] #957362
03/23/11 11:00 PM
03/23/11 11:00 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Got a picture of the pump?
Some pumps can be taken apart and the halves/sections clocked to face the inlet/outlet the way they need to face to clear everything.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Fuel Pump issue [Re: amxautox] #957363
03/23/11 11:04 PM
03/23/11 11:04 PM
Yuma, Az
ff6849 Offline OP
ff6849  Offline OP
Yuma, Az
here is the pic
Re: Fuel Pump issue [Re: ff6849] #957364
03/23/11 11:11 PM
03/23/11 11:11 PM
amxautox Offline
amxautox  Offline
Nope, can't rotate that one. I'd say take it back and see what another one looks like. Maybe they assembled it wrong.
Tom
author unknown
Re: Fuel Pump issue [Re: amxautox] #957365
03/23/11 11:35 PM
03/23/11 11:35 PM
Yuma, Az
ff6849 Offline OP
ff6849  Offline OP
Yuma, Az
it's actually is hitting up against the lower radiator discharge
Re: Fuel Pump issue [Re: ff6849] #957366
03/23/11 11:38 PM
03/23/11 11:38 PM
amxautox Offline
amxautox  Offline
Maybe it's for a different year that has the rad. hose on the other side.
But then a '73 Barracuda never did come with a 440. You'll probably have to look in the book at the store to see which has the outlet fitting in the proper/better position. Or someone here should know what to get and the part number.
Tom
author unknown
Re: Fuel Pump issue [Re: amxautox] #957367
03/24/11 09:17 AM
03/24/11 09:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
take it back and call summit. Holley and Carter sell pumps that you can rotate the entire bottom of the pump. This also allows you to replace the diaphram if it blows. Or you could just ask the parts guy if you and look for one that has a "screw in" fitting, that way you can elbow it.
Coming soon!!!!
Re: Fuel Pump issue [Re: Mr.Yuck] #957368
03/24/11 09:24 AM
03/24/11 09:24 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
you can still put a short 90 deg elbow in it and fasten it with short peices of hose or just bend a 90 yourself and connect it with hose.if you have about 1 inch to play with.
Re: Fuel Pump issue *DELETED* [Re: amxautox] #957369
03/24/11 09:25 AM
03/24/11 09:25 AM
Post deleted by RapidRobert
Re: Fuel Pump issue [Re: RapidRobert] #957370
03/24/11 11:09 AM
03/24/11 11:09 AM
scratchnfotraction Offline
you would need an 5/16 male inverted flare x 5/16 femal inverted flare x 90* to elbow that fuel pump
if they even make that fitting
the older carters that can have the bottom clock is the way to go and a much better fuel pump
Re: Fuel Pump issue [Re: scratchnfotraction] #957371
03/24/11 03:51 PM
03/24/11 03:51 PM
If one of your parts houses has an Edelman fittings section cabinet, they have an amazing array of fittings. According to the water pump inlet thread on this page you just need an early (pre '73) WP housing, they're pretty common and the pic is a common parts house "airtex" low perf fuel pump and very probably a '74 up fuel pump will have the fittings clocked different as a '74 up water pump housing inlet is on the same side as the fuel pump & obviously the fuel pump location never changed so '74 up they were kissing cousins on the pass side. I know on SB's those "airtex" pumps w the crimped seal come in several clockings and a select few of em if you search are actually 3/8" and I'm drilling my SB "airtex" which is required (class rules) to 3/8" nipples for more flow though I've yet to have starvation at 6200 RPM (~300 horse 360 9-1 2bbl) w a stock "airtex" 5/16" fuel pump. Holler how it turns out
Re: Fuel Pump issue [Re: RapidRobert] #957372
03/24/11 09:33 PM
03/24/11 09:33 PM
Yuma, Az
ff6849 Offline OP
ff6849  Offline OP
Yuma, Az
exchanged for this one sholud work with the inlet and outlet facing out.
