Re: 5.7L HEMI in a Pre-67 A-Body [Re: MuuMuu101] #957337
03/25/11 09:23 PM
03/25/11 09:23 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yes, a Dart Charger should have one. I think later production '65 Barracuda's had them available, while '64.5 and early '65 Barracudas did not.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 5.7L HEMI in a Pre-67 A-Body [Re: GO_Fish] #957338
03/25/11 10:21 PM
03/25/11 10:21 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
This link may help:
5.7 L Hemi in '67 Barracuda
Re: 5.7L HEMI in a Pre-67 A-Body [Re: Fab64] #957339
03/26/11 10:56 AM
03/26/11 10:56 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
This link may help:
Major differences, which is why he asked about PRE 67 A bodies.
As for the A body 83/4, if you find on in any year A body it will fit. The rear stayed the same in the later A's, only the front track widened but it was essentially in the frame and K member, the rest of the front is the same.
Don't be the exception.
Re: 5.7L HEMI in a Pre-67 A-Body [Re: Supercuda] #957340
03/26/11 01:01 PM
03/26/11 01:01 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
Try searching on www.forabodiesonly.com ......several build threads over there that can help ya
Re: 5.7L HEMI in a Pre-67 A-Body [Re: MuuMuu101] #957341
03/27/11 04:13 AM
03/27/11 04:13 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Cool. How much over 20 mpgs? Because an 07 Charger gets around 17st/25hwy mpgs and that has to be at the very least 500lbs heavier than an early Dart.
The specs on the Charger R/T show it to weigh upwards of 4200 lbs. An early A body with a 273 is in the 2700 range. The HEMI would probably raise it to the 2850 range with the additional girth, wiring and such. 1350 lbs of savings? Not too shabby!
Re: 5.7L HEMI in a Pre-67 A-Body [Re: Kern Dog] #957342
03/27/11 05:15 AM
03/27/11 05:15 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you want the 545-RFE your best bet is probably to run the Alterkation K so you lose the T bars, then cutting the rear crossmember isn't a problem...
Re: 5.7L HEMI in a Pre-67 A-Body [Re: 1_WILD_RT] #957343
03/27/11 02:20 PM
03/27/11 02:20 PM
ontario canada
dart443 Offline
dart443  Offline
ontario canada
I'm in the process right now!64 Dart,using RMS front suspension,Modern Muscle's wiring and computer,I modified the trans tunnel for 518 trans,any questions let me know!
Re: 5.7L HEMI in a Pre-67 A-Body [Re: dart443] #957344
03/28/11 05:32 PM
03/28/11 05:32 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Cool! Great! I will if I ever get to that project. The only thing is that RMS can get expensive if you decide to go all then way around the car. I am sure it will give you much less of a headache but I was just thinking of like a complete budget daily driver build. Something along the lines of making new mounts, upgrading the suspension, getting better disc breaks, 518 trans to handle Los Angeles traffic, etc. There is going to be a lot of fabrication, but I am sure that would be much cheaper then going with RMS. Anyway, that will be for much later (if I even get to it, have the money, and find a good enough car). I have a stick shift right now and if I have to drive in LA traffic to go to graduate school or for my job in the future, my feet will not be happy with me.
I already have a 68 Dart project right now and I am thinking about 6.1L with a 5 or 6-speed and an 8 3/4 with somewhere around 3.55-4.10 gears all under an RMS suspension. It is going to be pricey, but I think I am just going to try to elongate the project as much as possible so it will not be too big of a financial burden. Ideally I want to work on the car by myself as much as possible as a learning experience and to lower the costs of labor rather than having my mechanic doing it and not knowing or learning anything about my car.
