Re: 69 Dodge Superbee Disc Brake conversion help please
[Re: otto37]
#957173
03/23/11 07:32 PM
03/23/11 07:32 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Wow..That's crazy..I'm doing the same conversion RIGHT NOW on a 70 Super Bee 383 4spd. The only question I would have....When the conversion was done did they switch the proportioning valve ? How about the master cylinder? Did they use one for disc brakes? These are the things that I plan to change....I hope I don't have the same issue
CHECK OUT MY NEW WEB SITE !
[Re: otto37]
#957175
03/23/11 09:30 PM
03/23/11 09:30 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
My guess is that it still has the stock master cylinder and proportioning valve, but, I'm not really sure what I should be looking at as far as part numbers, etc. I'm hoping someone can tell me what master cylinder and proportioning valve I need, and maybe who I should call to get the right parts.
Thanks, Mike
There is a DISTRIBUTION block that all the lines connect to , it is the same in 1969 for disc and drum brakes , there will be a valve in the line going to the rear brakes on a disc brake car. , does it still have the drum brake master cylinder in it , if so there is the first part to be replaced .
[Re: JohnRR]
#957176
03/24/11 01:39 AM
03/24/11 01:39 AM
Posts: 3,663 st louis mo
Q5Bee B5ScatPack
st louis mo
Go to Napa or wherever you get parts from and ask for a 1972 charger power disc brake MC. As far as the propotioning valve,it is easier to go with the aftermarket adjustable one than the repop factory DBPV.
1969 SUPERBEE 383 Q5 RED STRIPE WHITE INT. 2015 CHALLENGER SCAT PACK B5 BLUE 1996 INDY RAM PACE TRUCK
[Re: Kern Dog]
#957178
03/24/11 08:33 AM
03/24/11 08:33 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Ive done a few conversions.I use 69 C body manual masters.I have one on my 65 and one on my kids 62 300. they stop great even at 120.Check the pads also.Make sure they arent glazed or cheapies.I run ceramic pads on my front rotors.Rocky
Chrysler Firepower
