Variable timing (MSD 8680) and Mopar Orange box #957163
03/23/11 07:02 PM
03/23/11 07:02 PM
Tampa, FL
Saint Crispan Offline OP
Tampa, FL
I'm sure that nearly anyone on this board could tell me where to find the wiring diagram for using an MSD 6 series box, but does anyone have a diagram handy for using the 8680 and a Chrysler orange box? I just bought the orange from Summit, so I don't want to upgrade to the MSD 6 just yet.
If it helps, it's brand new...I haven't even wired it in yet. The car is a '72 SSP, with a 400 which is currently points.
Thanks in advance for any assistance.
Re: Variable timing (MSD 8680) and Mopar Orange box [Re: Saint Crispan] #957164
03/23/11 07:18 PM
03/23/11 07:18 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Must be used with a MSD ignition control.
http://www.summitracing.com/parts/MSD-8680/
My
Own
Personal
Adrenaline
Rush
Re: Variable timing (MSD 8680) and Mopar Orange box [Re: Moparzrule] #957165
03/23/11 08:40 PM
03/23/11 08:40 PM
I have one of those I wanna use & I missed that too
Re: Variable timing (MSD 8680) and Mopar Orange box [Re: RapidRobert] #957166
03/24/11 12:35 PM
03/24/11 12:35 PM
Tampa, FL
Tampa, FL
Well, nuts.
Anyone want to buy an orange box, with wiring...pretty cheap?
I'm going to keep the disti, because I'm pretty sure that the MSD 6 will work with it...or will it?
Thanks to all contributors.
Re: Variable timing (MSD 8680) and Mopar Orange box [Re: Saint Crispan] #957167
03/24/11 03:31 PM
03/24/11 03:31 PM
(1) w the rep that the orange box has (here) it's gonna b pretty hard to sell it & if it's till new I would for sure send it back to summitt. I believe you can use points to trigger the MSD 6
Re: Variable timing (MSD 8680) and Mopar Orange box [Re: Saint Crispan] #957168
03/24/11 04:36 PM
03/24/11 04:36 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
MSD used to make a standalone unit that provided up to 20 degrees of ignition retard, and could be used with just about any factory or after-market ignition, as it did the retard in the wiring to the ignition coil.
I can't remember the part number right now, but I bought one about 1999 and still have it in storage somewhere.
You might ask MSD tech support what the part number was, then search the web for a used one for sale.
Re: Variable timing (MSD 8680) and Mopar Orange box [Re: RapidRobert] #957169
03/24/11 06:02 PM
03/24/11 06:02 PM
Tampa, FL
Tampa, FL
There appears to be a way, in the wiring diagram, that the points disti will work with the MSD 6, but I was referring to using the electronic distributor which came with the kit...
I had planned to upgrade the car from points to electronic...but that was before I found the variable timing module. After I found that, I figured to put that in too.
I thought I saw in the diagram a method of hooking directly up to the electronic distributor...but are you saying that it can't be done that way?
I thought I also saw an instruction which said not to hook up the vacuum assist on the disti...now does that make any sense?
Re: Variable timing (MSD 8680) and Mopar Orange box [Re: Saint Crispan] #957170
03/24/11 06:04 PM
03/24/11 06:04 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
PM me with how much you want for the orange box and harness. Tim
Re: Variable timing (MSD 8680) and Mopar Orange box [Re: Saint Crispan] #957171
03/24/11 07:07 PM
03/24/11 07:07 PM
yes it does & was wondering that myself as I want to keep vac adv & w the dist just being a trigger & the vac adv is going to b changing the trigger point if/why that is a prob w it. I'm going to call MSD & ask em. EDIT they did tell me way back that the programmable (3 adjustments iirc) timing box they sell cannot b used w vac adv but this adjustable one, if I cant use vac adv it'll hurt me more than any gain I might get from their toy & pretty sure vac adv can b use w the one we are referring to
