replace brake booster #957153
03/23/11 06:25 PM
03/23/11 06:25 PM
st louis
curry58 Offline OP
curry58  Offline OP
st louis
anybody know whats involved in replacing brake booster on 1968 b-body
Re: replace brake booster [Re: curry58] #957154
03/24/11 02:42 PM
03/24/11 02:42 PM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
1) Unbolt pedal from linkage
2) There's another both that holds the linkage to the brake pedal frame. Remove that bolt
3) remove spring attached to linkage
BTW the linkage comes out with the booster
4) Unbolt 4 nuts that hold booster to firewall
5) Unbolt master. I've been able to rig it where I haven't taken off the lines from the master just moving it out of the way.
5a) remove vacuum line
6) Remove booster
7) Remove linkage from booster. Note that there is a bushing in the rod in the back of the booster. Don't lose it because nobody makes it.
8) Reverse to install
Re: replace brake booster [Re: 65Frank] #957155
03/25/11 01:09 AM
03/25/11 01:09 AM
Central TX
roe Offline
roe  Offline
Central TX
6) Remove booster
I skipped some of this. All I did was disconnect the linkage from the booster (one pin), and then the 4 bolts from the booster, and disconnect the master cyl from the booster. All my pedal linkage stayed intact. I did have a really long set of needle nose pliers though, to let me R&R that little pin.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: replace brake booster [Re: roe] #957156
03/25/11 09:48 AM
03/25/11 09:48 AM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
On my '67, I didn't see any way to disconnect the linkage from the arm on the booster while it was still on the car; the was no clearance to get a wrench in there or to get the bolt out for that matter. I'll have to look at it again next time I do one.
Re: replace brake booster [Re: curry58] #957157
03/25/11 04:07 PM
03/25/11 04:07 PM
st louis
curry58 Offline OP
curry58  Offline OP
st louis
Re: replace brake booster [Re: 65Frank] #957158
04/04/11 12:01 AM
04/04/11 12:01 AM
Central TX
roe Offline
roe  Offline
Central TX
My car is a '71 so it may be a little different
