Re: Who uses M/T slicks? [Re: tboomer] #957055
03/23/11 08:53 PM
03/23/11 08:53 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
M/T 13" x 31" here Ted. So far, so good on the bite.
Only 41 passes on them to date.
Re: Who uses M/T slicks? [Re: kdhull] #957056
03/23/11 08:53 PM
03/23/11 08:53 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
I have 6 years on my ET streets. They are used up and need to be replaced. should have been in 09. But they still have tons of tread on them for street use. I have lost about a .1 on my 60ft. But this is a given as there are 1500 miles and maybe 300 passes on the tires.
I will be getting another set of MT but slicks this time.
Re: Who uses M/T slicks? [Re: S/ST 3040] #957057
03/23/11 08:57 PM
03/23/11 08:57 PM
ellenwood,georgia
K
kdhull Offline
kdhull  Offline
K
ellenwood,georgia
Man, that is one hellofa nice ride.where you located at???
Re: Who uses M/T slicks? [Re: kdhull] #957058
03/23/11 09:09 PM
03/23/11 09:09 PM
ellenwood,georgia
K
kdhull Offline
kdhull  Offline
K
ellenwood,georgia
Oh well here we go,Was it OK to ask where he is located????? Mods check in here.Dad burn people want to hide where they are at??? I'm in Ellenwood
Georgia. Kermit the name and don't give a butts butt
about your petty games. And now I get all the ##
What's the matter guys you think joeychicago is the
man hell he's the man that keeps you assh@@@
straight>kermit
Re: Who uses M/T slicks? [Re: kdhull] #957059
03/23/11 09:16 PM
03/23/11 09:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Who uses M/T slicks? [Re: pittsburghracer] #957060
03/23/11 10:37 PM
03/23/11 10:37 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
MT's tend to lose circumference compared to Phoenix. They also have fatter section width. If you compare 11.5-29.5-15's, you will get my drift. As far as hook, can't say.
Re: Who uses M/T slicks? [Re: Leigh] #957061
03/23/11 11:22 PM
03/23/11 11:22 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
You can't go wrong with M/T slicks IMO. My last set I bought with a half dozen passes on them. And as life goes my car did not get finished for a few more years. When I replaced them in 09, Mike at Harlow tire asked if he was reading the date code correct. They had a 1995 date code. Last pass on them had a 1.41 60 ft. First pass on the new set was a 1.401 60 ft. Same tires that are on it now and they have went a best of 1.349 with the rear tires. They also do not require a big burn out either.
Re: Who uses M/T slicks? [Re: Bigbeep] #957062
03/24/11 03:39 AM
03/24/11 03:39 AM
WA
JD Dart Offline
JD Dart  Offline
WA
Everyone will have different opinions I had a set of M/T 33X15X17 had 175 passes on them still lots of thread left but they went away 25 passes before that. I would have to due a longer burn out just to get the car to hook consistently. Put on a set of Goodyear 33X15X15 stiff side walls and the reaction time of the car was much quicker had to add .019 to the box. But I due miss the 17” width next set will be 33X15X17 make it a better bracket car on full out passes. Just a side note the M/T coming of the stop was a hand full the GY handle perfect off the stop. But maybe the side walls were dead on the M/T long before that.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Who uses M/T slicks? [Re: JD Dart] #957063
03/24/11 08:15 AM
03/24/11 08:15 AM
Mo.
racerx Offline
racerx  Offline
Mo.
That's what i like about them had a set 4 about 5 years now and still goes a 1.35 60's off the foot brake i think the next set would be a 29.5 10.5 on a 12"rim.I'm currently running a 29.5 10.5 w.
Re: Who uses M/T slicks? [Re: JD Dart] #957064
03/24/11 08:16 AM
03/24/11 08:16 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,guys! Looks like M/T will be ok...I will wait till I get the go ahead from bad1970dust to get them on order..
