426 hemi engine mount question #956856
03/23/11 11:54 AM
03/23/11 11:54 AM
Beans Cove Pa
Bumbalawski Offline OP
Beans Cove Pa
I am going to build a 426 hemi for a friend. He purchased a new hemi block in 1994 which has both hemi and "440" mounting lugs on it. He prefers to use the "440" mounts since he does not have a hemi K-member. He has chassis headers (hemi) for it also.
My question is this: Will the chassis headers work (clear) on this engine using the 440 mounts? It is going in a 70 Cuda. I am sure someone out there has dealt with this situation.
PM me or dodgeboy69@atlanticbb.net
Thanks,
Don
Re: 426 hemi engine mount question [Re: Bumbalawski] #956857
03/23/11 11:59 AM
03/23/11 11:59 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
the easy thing to do would buy the schumaker mounts for it to convert it from 440-Hemi. Thats what we did with a 69 coronet and are going to be doing with a 383 Road Runner. both with under body headers. show cars to boot.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: 426 hemi engine mount question [Re: Bumbalawski] #956858
03/23/11 03:00 PM
03/23/11 03:00 PM
Walla Walla, WA
Hemi_Jack Online content
Hemi_Jack  Online Content
Walla Walla, WA
The headers will clear on the passenger side but I have heard they will not clear the mount on the drivers side.
Re: 426 hemi engine mount question [Re: Hemi_Jack] #956859
03/23/11 05:14 PM
03/23/11 05:14 PM
wi
crscuda Offline
crscuda  Offline
wi
Look in arruzza's web site. He sells some nice looking hemi mounts. I have not tried them.
Re: 426 hemi engine mount question [Re: crscuda] #956860
03/23/11 07:52 PM
03/23/11 07:52 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Most Headers will not clear the 440 mounting on the drivers side.
You can buy the custom headers intended for this or, grind off the tabs on the block and use the Hemi mounts with the correct brackets and special K frame..
Re: 426 hemi engine mount question [Re: sthemi] #956861
03/23/11 08:13 PM
03/23/11 08:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I talked to a guy who did just what you describe, he said he had to grind a bit on the one mounting lug for clearance and ding a header tube a little.
Re: 426 hemi engine mount question [Re: Bumbalawski] #956862
03/23/11 09:27 PM
03/23/11 09:27 PM
pawling n.y.
cudachas Offline
cudachas  Offline
pawling n.y.
I used the Arruzza mounts on my 70 cuda hemi crate motor and had zero issues with engine position and TTI header fitment.Good luck!
