A Body crossmember w/ RB-727 will trans fit? #956705
03/23/11 12:35 AM
03/23/11 12:35 AM
VT
MOPARCRAZY Offline OP
VT
Does the upper side of the trans crossmember in a 67-76 A body need to be modified to fit a 727 behind a 440? Is so, any pics?
Thanks!
Re: A Body crossmember w/ RB-727 will trans fit? [Re: MOPARCRAZY] #956706
03/23/11 02:50 AM
03/23/11 02:50 AM
Cab_Burge Online work
Cab_Burge  Online Work
Thanks!
No mods needed 1967 was the first year Ma Mopar installed the 383 in the A bodys stock from the factory As long as you have V8 trans crossmember and tranny mount your golden on the back part What are you going to use for mounts on the front? I like and use Elephant ears or a front motor plate mounted to top of the front frame rails
Re: A Body crossmember w/ RB-727 will trans fit? [Re: Cab_Burge] #956707
03/23/11 03:03 AM
03/23/11 03:03 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
IS there a difference in slant sick and V8 trans x members?
I thought that they were all the same.
They seem to be from '73-76 anyway.
Re: A Body crossmember w/ RB-727 will trans fit? [Re: Cab_Burge] #956708
03/23/11 04:36 AM
03/23/11 04:36 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Tranny tunnel needs modified for shield! Depending on headers the upper cross
Member may needed modified
Mopar Performance
Re: A Body crossmember w/ RB-727 will trans fit? [Re: moparniac] #956709
03/23/11 05:02 AM
03/23/11 05:02 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the crossmember is fine, it's just the tunnel that needs clearencing with a shield.
Re: A Body crossmember w/ RB-727 will trans fit? [Re: rebel] #956710
03/23/11 09:28 AM
03/23/11 09:28 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I just had to flatten out the lip on the underside of the trans tunnel to get the trans in, no other mods were needed.
Re: A Body crossmember w/ RB-727 will trans fit? [Re: Dodgeguy101] #956711
03/23/11 03:38 PM
03/23/11 03:38 PM
VT
VT
Thanks for the help!
Re: A Body crossmember w/ RB-727 will trans fit? [Re: MOPARCRAZY] #956712
03/24/11 10:58 AM
03/24/11 10:58 AM
NC
440Jim Offline
440Jim  Offline
NC
And for what it is worth,
I put a mid '70s trans cross member in my '69 Dart so I could use the newer style trans mount (spool type).
Re: A Body crossmember w/ RB-727 will trans fit? [Re: 440Jim] #956713
03/24/11 01:36 PM
03/24/11 01:36 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
my crossmemebr was modified to fit the proparts headers...
Mopar Performance
