Drive shaft size #956666
03/22/11 10:25 PM
03/22/11 10:25 PM
Real North Cal.
66er Offline OP
66er  Offline OP
Real North Cal.
What drive shaft size does my buddy need. The car is aprox. 3000#, 5500 stall 4.30, 30" tire, 388ci W7 sb 682 hp at 7000 rpm. He also want to be able to hit it with up to a 500 shot of nitrous down track. The shaft need to be aprox. 51" long.
Re: Drive shaft size [Re: 66er] #956667
03/22/11 10:36 PM
03/22/11 10:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont have someone guess at it.... call Dynotech
http://www.dynotechengineering.com/
Re: Drive shaft size [Re: MR_P_BODY] #956668
03/23/11 09:23 AM
03/23/11 09:23 AM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
I've had great results with Shaftmasters drive shafts in both Steel and Aluminum. Check them out on the web. Dave can fix you up with all the info you'll need. Nice Guys and Great prices too.
