the age old question.... what cam should i buy?
#956574
03/22/11 07:51 PM
03/22/11 07:51 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
hello all. i'm new to big block mopars but not to high performance engines. i have a 68 coronet rt that is all original type equipment (carter avs, 906 heads, hi-po manifolds, 323 rear end etc....) and i'm thinking of replacing the cam and lifters (and the timing chain and valve springs) with something that has a bit of a "muscle car" idle to it. the car sounds like an old station wagon with the stock cam. i'm looking for opinions on what would be a good cam to buy. i want to keep it very streetable but i really want to hear a cool lope. i don't want to get into fly cutting pistons and expensive roller rocker arms and i plan on keeping the hi-po manifolds. any ideas?
unions....the folks who brought you the weekend!
Re: the age old question.... what cam should i buy?
[Re: 68-scatpack-rt]
#956575
03/22/11 07:58 PM
03/22/11 07:58 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
cool lobe is over-rated it's better to have a good running engine. Buddy took your basic combo in a 68 charger, added summit 488 cam, headers, t-chain, MP electronic ing, DP4B intake (I think) stuck w/ the Cater carb and the car ran 14.10 driving like grandma. it will work with mani's. You could also look at the mopar 528 solid, although it would like a little more gear.
#956578
03/22/11 08:24 PM
03/22/11 08:24 PM
Mr.Yuck
Brookeville, Md
i'm thinking i can have both a good running engine and a cool lopey idle.
not really. Usually cams that lope have a 106-108 centerline and are designed for racing and they will run TERRIBLE in a non-performace engine. They also pull terrible vacuum so good luck tuning the carb just right. What you want is a sound that is chrisp under WOT. If you want the car to shake turn the idle down.
[Re: 5spdcuda]
#956580
03/22/11 08:47 PM
03/22/11 08:47 PM
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
i've used cam motion to do some custom cams for my ford stuff. i might give them a shout.
that comp 274 looks like it might be a good choice as well.
[Re: DaytonaTurbo]
#956583
03/22/11 09:44 PM
03/22/11 09:44 PM
Posts: 3,095 Idaho
Runner
Idaho
call dwayne porter and order a cam from him. great guy to deal with. 802-951-1955 what ive found with dealing with him is, he accually listens to what you want and trys to give you the best product for that.
and you can have some lope with a cam with a 112 centerline.
[Re: cjs69mope]
#956585
03/23/11 01:43 AM
03/23/11 01:43 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
You would obviously know better than me since you've used this cam before, but it looks to me like the Summit 488 cam has about 62 degrees of overlap which should make that cam pretty lopey, no???
[Re: Runner]
#956586
03/23/11 09:31 AM
03/23/11 09:31 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
[Re: rss]
#956587
03/23/11 09:58 AM
03/23/11 09:58 AM
Mr.Yuck
Brookeville, Md
it has a little lope but nothing like the MP cams. I've run a few of them as well. My bone stock 67 GTX went from 14.20 to 13.82 with just a cam change and my mild 440 in my 67 Coronet went 12.90. When I bought the car it had a mopar 484 cam and was a dog. It didn't have enough stall or compression for the cam to work right.
[Re: 62maxwgn]
#956589
03/23/11 11:34 AM
03/23/11 11:34 AM
Mr.Yuck
Brookeville, Md
I personally wouldn't take any individual's recommendation (well,maybe one or two) on choosing a cam.What works for one doesn't always work for others.Call a cam grinder,tell them what you have and what you would like,you'll be much happier in the end,that is unless you enjoy changing cams.
that be ture. You can have cams ground up for about the same cost as a shelf unit these days.
[Re: Mr.Yuck]
#956590
03/23/11 01:20 PM
03/23/11 01:20 PM
rss
Seattle, WA
The MP 484 cam has a bit more overlap than the Summit cam. The Summit 488 seems more similar to the MP 474.
[Re: rss]
#956591
03/23/11 04:34 PM
03/23/11 04:34 PM
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
called cam motion today. they get 190 for a custom ground 440 cam and 95 for the matching lifters. the rep told me they will only use german made cores now as the domestic cores have proven unreliable. i'll post up the recommended specs as soon as i hear back from them. thanks for the input gents! have a great night, rob
