15x8 with 4.5" backspacing on 1971 cuda? #956349
03/22/11 02:23 PM
03/22/11 02:23 PM
Sweden
71redcuda Offline OP
Sweden
Hello..
Im intrested to buy a set of steeles for my cuda with original 8 3/4 rear end.
I was thinking 15x7" in front and 15x8 with 4" or 4.5" backspacing in the back of the car.
Do anyone know if there will be any problem for to fit 15x8 with 4.5" backspace wheels on the back of the car??
Will be using 255mm (10") wide tires in back
Maby i should go with 15x7" in the back instead?
thanks,
Nicklas Larsson -Sweden
Re: 15x8 with 4.5" backspacing on 1971 cuda? [Re: 71redcuda] #956350
03/22/11 02:25 PM
03/22/11 02:25 PM
Outside
thedriver Offline
thedriver  Offline
Outside
those wheels fit perfect on my challenger. biggest tire i could fit was a 275 60 tho.
1973 challenger
Dana. 4 speed. Low deck.
Re: 15x8 with 4.5" backspacing on 1971 cuda? [Re: 71redcuda] #956351
03/22/11 02:56 PM
03/22/11 02:56 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I have 15X8 with 4.5 backspacing on my Cuda. 275/60R15 BFG TA. Fits great - better than a 7" wheel in my opinion. Gives a 1" gap between the trim ring and wheel center though. Its the only way to run an 8" wheel without relocating the springs inward. Would look weird if you did that anyway.
Re: 15x8 with 4.5" backspacing on 1971 cuda? [Re: PAINT IT BLACK] #956352
03/22/11 09:15 PM
03/22/11 09:15 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I also have 15X8 with 4.5 BS and 275/60R15 BFG Drag Radials on a 70 Barracuda.
Re: 15x8 with 4.5" backspacing on 1971 cuda? [Re: 71redcuda] #956353
03/22/11 10:55 PM
03/22/11 10:55 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
I would suggest searching the archives some. Everyone has a slightly different opinion of a "good fit". Fit covers both interference and appearance.
I would not expect there to be any issues with 255/60/15 on the 15X8 4.5BS wheel. A 275/60/15 on the same rim may be a slightly different story, depending on your vehicle ride height and how much suspension compression could occur during extremes of your driving.
Search for "275/60/15" in the Q&A to see an old post of mine where I expressed my opinions of fitment on a 70 Cuda.
My suggestion is to gather various opinions, look at many pictures as possible, and take lots of measurements!
Good luck!
Re: 15x8 with 4.5" backspacing on 1971 cuda? [Re: davenc] #956354
03/23/11 03:15 AM
03/23/11 03:15 AM
Sweden
Sweden
Thanks everyone!
I appreciate the help from you guys.
I will take a look in the archive also.
Re: 15x8 with 4.5" backspacing on 1971 cuda? [Re: 71redcuda] #956355
03/23/11 01:25 PM
03/23/11 01:25 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
That is the exact wheel on the back of my Charger with 295/50/15's on the rear.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 15x8 with 4.5" backspacing on 1971 cuda? [Re: 6PKRTSE] #956356
03/23/11 01:26 PM
03/23/11 01:26 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
One more.
