#956276 - 03/22/11 10:17 AM removing lenses-A body ralley dashes
340wedge Offline
Loc: Myrtle Beach, SC formerly the ...
How do you remove the lenses and gauge from a A body Ralley Dash. They look like they are plastic welded or glued on the back with a
plastic stud type of thing?..
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
#956277 - 03/22/11 04:24 PM Re: removing lenses-A body ralley dashes [Re: 340wedge]
Sixpak Offline
Loc: The Swamp
They were originally studs the lenses slipped over and then the studs were melted, the same thing they do today to assemble an all-plastic door panel from many separate molded sections. Bust the melted over stud material carefully, leaving just a nib to sit the lenses back on and then glue them back in place. Devcon / Permatex makes an excellent Plastic Welder cement, 2 part, stinks awful but really works. Fixed many door panels, grills with the stuff.
#956278 - 03/22/11 06:52 PM Re: removing lenses-A body ralley dashes [Re: Sixpak]
340wedge Offline
Thank you sixpack
#956279 - 03/22/11 09:05 PM Re: removing lenses-A body ralley dashes [Re: 340wedge]
belv2vert66 Offline
Loc: Back In Iowa
I used a soldering iron. If you get the temperature just right, and pull up on the lens a bit, the plastic will conform to the hole and leave you with a stud to remelt. That's how I did mine anyway.....
25,345 Registered Members
190,204 Topics
Anyone familiar with ultrasonic cleaners?
by magnum440d100
Today at 04:33 PM
Lifter tick and oil through pushrods
by Fishmarket
Today at 04:26 PM
1978 DRAPER MOTOR COMPANY KENTERA
by theraif
Today at 04:25 PM
Probably has some interesting trade prospects
by Govierjr.
Today at 03:21 PM
