#956276 - 03/22/11 10:17 AM removing lenses-A body ralley dashes
340wedge Offline
Loc: Myrtle Beach, SC formerly the ...
How do you remove the lenses and gauge from a A body Ralley Dash. They look like they are plastic welded or glued on the back with a
plastic stud type of thing?..
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
#956277 - 03/22/11 04:24 PM Re: removing lenses-A body ralley dashes [Re: 340wedge]
Sixpak Offline
Loc: The Swamp
They were originally studs the lenses slipped over and then the studs were melted, the same thing they do today to assemble an all-plastic door panel from many separate molded sections. Bust the melted over stud material carefully, leaving just a nib to sit the lenses back on and then glue them back in place. Devcon / Permatex makes an excellent Plastic Welder cement, 2 part, stinks awful but really works. Fixed many door panels, grills with the stuff.
#956278 - 03/22/11 06:52 PM Re: removing lenses-A body ralley dashes [Re: Sixpak]
340wedge Offline
Thank you sixpack
#956279 - 03/22/11 09:05 PM Re: removing lenses-A body ralley dashes [Re: 340wedge]
belv2vert66 Offline
Loc: Back In Iowa
I used a soldering iron. If you get the temperature just right, and pull up on the lens a bit, the plastic will conform to the hole and leave you with a stud to remelt. That's how I did mine anyway.....
25,495 Registered Members
193,119 Topics
1970 Dodge Monaco Production Figure Source??
by DeMopuar
Yesterday at 10:40 PM
Some people have life so tough
by pittsburghracer
Yesterday at 10:38 PM
Pigtail setups for trapped starters
by Hot 340
Yesterday at 10:03 PM
Steering parts
by Nick Stevanovski
Yesterday at 09:13 PM
