which 8 3/4 rear is wider? 66-67 or 68-70? #956003
03/21/11 10:19 PM
03/21/11 10:19 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
i need to know which is wider.i have a 67 rear.was thinking about moving the spring perches on it and put it in my 72 duster
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: 1bad318] #956004
03/21/11 10:29 PM
03/21/11 10:29 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I think there is a chart in the tech archives, but I have always thought the 68 on 8 3/4 was slightly wider
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: belv2vert66] #956005
03/21/11 10:35 PM
03/21/11 10:35 PM
IN
ahy Offline
ahy  Offline
IN
The link to the axle width chart is attached.
http://www.moparts.org/Tech/Archive/axle/16.html
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: 1bad318] #956006
03/21/11 11:04 PM
03/21/11 11:04 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The 68-70 is wider. Some members have just forced the springs into place putting a B body rear in their a body , it's something I would do though.
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: JohnRR] #956007
03/22/11 01:23 AM
03/22/11 01:23 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Its a cheap and dirty move to spread the springs. This places undue stress on the shackles and bushings. A decent tech can save the spring pads when removing them and simply move them inboard the 1/2" each side.
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: Kern Dog] #956008
03/22/11 01:31 AM
03/22/11 01:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes they can be saved, I've done it, but sometimes it's easier to cut the old ones off & install new ones.. The MP spring perch kit is only $12 from Summit..
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: Kern Dog] #956009
03/22/11 01:34 AM
03/22/11 01:34 AM
Under My Car
Mopar_Country Offline
Under My Car
I was on another forum and there was a guy that did just that and saw nothing wrong with it. He even posted a pick, and even though it's only a half inch on either side you could see the strain it was putting on the spring, not good.
I can't speak for him, but I think John meant it's something he wouldn't do.
You will also need to run a bigger backspace on the wheels too.
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: Mopar_Country] #956010
03/22/11 01:48 AM
03/22/11 01:48 AM
JohnRR Offline
JohnRR  Offline
I would definitely not do it , there are some on this site that have done it and see no problem with it . I'm not sure why I mentioned it , but I know someone will eventually jump in saying ... come on in the waters fine .
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: JohnRR] #956011
03/22/11 01:55 AM
03/22/11 01:55 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I knew that it was a typo John, I know you're intelligent enough to know whats right.
The Mancini spring plates may work, but the 2 sets I bought from Summit had pilot holes too large for me. Thats why I save the stock pads. I've modified 4 axles in the last 3 years this way.
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: Kern Dog] #956012
03/22/11 02:04 AM
03/22/11 02:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Were the plates the Mopar Performance pieces? I just bought a set & they were Ok..
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: 1_WILD_RT] #956013
03/22/11 02:47 AM
03/22/11 02:47 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The plates WERE the MP units. The holes were larger. My wild guess is that the holes were about 5/8" and the stockers were about 7/16".
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: Kern Dog] #956014
03/22/11 02:50 AM
03/22/11 02:50 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Mopar Stockers are 1/2" GM stockers are 19/32''.... 1/32'' smaller than 5/8'' so I'm sure thats what they sold you... Thanks MP... Nothing new...
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: Kern Dog] #956015
03/22/11 02:55 AM
03/22/11 02:55 AM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
thanks guys
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: ahy] #956016
03/22/11 02:58 AM
03/22/11 02:58 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Wait, I am confused. According to this all A-body 8 3/4 are the same length from 66-72.
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: MuuMuu101] #956017
03/22/11 03:52 AM
03/22/11 03:52 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
They are... 52 5/8" and 57 1/8 total
I've spread the springs before, not my favorite thing to do. I prefer to move the perches.
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: RobX4406] #956018
03/22/11 11:49 AM
03/22/11 11:49 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
MP Spring perches are actually OEM Dakota pieces.
The 5/8" pilot hole in the perch is a non-issue because the housing is also located off the 1/2" hole in the shock plate.
If you are worried about the perch pilot hole, a lock washer under the head of the spring center bolt works as a bushing.
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: DoctorDiff] #956019
03/22/11 02:36 PM
03/22/11 02:36 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Hmmmmm. I never considered the shock plate as a locater.
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: Kern Dog] #956020
03/22/11 02:49 PM
03/22/11 02:49 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Any decent 4x4 shop should have leaf spring bolts with a larger diameter head that will fill up the gap on the MP spring perches.
Re: which 8 3/4 rear is wider? 66-67 or 68-70? [Re: Neil] #956021
03/22/11 03:29 PM
03/22/11 03:29 PM
Under My Car
Under My Car
I have used a pipe nipple welded in the hole, ground off flush on both sides and drilled accordingly.
