440 electronic conversion? #955636
03/21/11 04:43 PM
03/21/11 04:43 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
need a kit for a 440 in a 66 newport. dont want a pertonix.
i see that the MP kits are know in the $225-250 range. i also see the Prform kits in the $150 range.
any reason not to use proform?
Re: 440 electronic conversion? [Re: 05dakota] #955637
03/21/11 05:21 PM
03/21/11 05:21 PM
No exp w it but for cheap and just as good, get a 440 elec dist from a JY and a $15 black 4 pin Mopar ECU from a parts house and take apart the dist & solvent wash/dry/lube & might ch the vac adv can & for sure toss the heavy spring w the long loop on one end. Lastly would b your choice of coil and the right ohm ballast to go along w it. Many options there. You'll save money & if you tweek each dist subsystem in order you'll b happy w the outcome.
Re: 440 electronic conversion? [Re: RapidRobert] #955638
03/21/11 05:23 PM
03/21/11 05:23 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
no way will i find a jy 440 dist up here in rusty upstate ny.
Re: 440 electronic conversion? [Re: 05dakota] #955639
03/21/11 05:26 PM
03/21/11 05:26 PM
Yeah they dont call this the rust belt for nothing. Easier would b to buy one in the BB parts for sale here to your mailbox
Re: 440 electronic conversion? [Re: 05dakota] #955640
03/21/11 05:35 PM
03/21/11 05:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you should be able to buy one rebuilt from the parts store , but the NEW MP units have an adjustable mech advance which makes setting them up much easier ?
Why don't you want a Pertronix ? The electronics is just as reliable , or unreliable , as an MP box .
Re: 440 electronic conversion? [Re: JohnRR] #955641
03/21/11 05:42 PM
03/21/11 05:42 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
Have had 2 ignitors fail on me.
Re: 440 electronic conversion? [Re: 05dakota] #955642
03/21/11 05:43 PM
03/21/11 05:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How old were they ???
Re: 440 electronic conversion? [Re: 05dakota] #955643
03/21/11 05:44 PM
03/21/11 05:44 PM
Which ones were they as I've been wanting to do my 1st pertronix conversion (prob a II) w the correct flamethrower coil for the II kit
Re: 440 electronic conversion? [Re: JohnRR] #955644
03/21/11 05:44 PM
03/21/11 05:44 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
neither had more than 5000 miles on it.
Re: 440 electronic conversion? [Re: RapidRobert] #955645
03/21/11 05:45 PM
03/21/11 05:45 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
one was a I and other was a II.
Re: 440 electronic conversion? [Re: 05dakota] #955646
03/21/11 05:52 PM
03/21/11 05:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Considering you don't go anywhere .. ... The I must have been pretty old and before they moved manufacturing OVER THERE , so I'm surprised it failed so soon , the II ???.
Re: 440 electronic conversion? [Re: JohnRR] #955647
03/21/11 05:53 PM
03/21/11 05:53 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
WHATEVER, but i would rather change a mopar box on the side of the road than reinstall points.
Re: 440 electronic conversion? [Re: 05dakota] #955648
03/21/11 06:00 PM
03/21/11 06:00 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I put a procomp ready to run distributor on my 440. Costed me 50 something bucks on ebay. 2 wires to the coil and I was good to go.
Re: 440 electronic conversion? [Re: 05dakota] #955649
03/21/11 06:48 PM
03/21/11 06:48 PM
thanks Dakota; & Daytona, a ready to run procomp for ~$50, the price doesn't sound bad. I gotta do one Pertronix as Scratchn has convinced me that they are a killer setup, gonna be interesting to see how it compares to the HEI/Accell super coil I used w NO ballast (didn't know you were supposed to use one)
