laytex or rubber? which one would you use? #955189
03/21/11 12:07 PM
03/21/11 12:07 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Ok that title should get a big post count huh? We have to get a trunk weather strip for a customers 66 chebby. I called classic industries and they said they have a rubber one for about 20 bucks and a laytex one for like 79 bucks. Anyone run into that on any other weatherstrips? The guy just would tell me that one was softer than the other.
thanks
corey
Contact Me about AMD Prices
Re: laytex or rubber? which one would you use? [Re: hotairballoonpilot] #955190
03/21/11 03:17 PM
03/21/11 03:17 PM
South Dakota
South Dakota
41 looks but no ideas? wonder what all got on thier minds?
Re: laytex or rubber? which one would you use? [Re: hotairballoonpilot] #955191
03/21/11 05:37 PM
03/21/11 05:37 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
because he didn't really know either. Usually in common American usage, rubber is the most general term and latex is slightly more more specific. Depending on context, I sometimes can tell if latex is refering to natural rubber (derived from the sap) or a synthesized product. Much of latex paint today is an acrylic emulsion with no latex ruber at all. (which is one reason why wood windows and doors painted with latex paints stick and jam - use oil/alkyds)
http://encyclopedia2.thefreedictionary.com/Latex+(rubber)
So you see its going to be very hard to answer your question since the salesman didn't really give you enough information to base a decision on. They might diffrent material, but they might also be different constriction and even different profile. In fact, my experience is that you want to see the profile (cross section) of any so called reproduction weatherstrip part.
edit: a Chebby? There should be lots of sources, but if you have trouble finding cross sections or just getting the run arround on facts, try Restoration Specialty Supply (might be Restoration speciaties supplies, inc) in Wind gap or windber, Pa. (Sorry my catalog is not here). They may even have an on-line catalog now. Mopar stuff too. They made the belt weatherstrips (window felts) for my Baracuda using the correct material based on the originals from the car. The incorrect ones of course didn't function very well.
Re: laytex or rubber? which one would you use? [Re: Mattax] #955192
03/21/11 07:35 PM
03/21/11 07:35 PM
South Dakota
South Dakota
thanks. I did ask him if he had hight or cross section profile and he had none. He even ssaid well you need to trim it to fit the length. I said no I want to know the height and he had no info on that. Will try calling and seeing if I get another guy. I did join chevytalk.org and asked another question on where to buy door and 1.4 window eatherstrip and have gotten very little help. not the info like moparts is!
Re: laytex or rubber? which one would you use? [Re: hotairballoonpilot] #955193
03/21/11 07:39 PM
03/21/11 07:39 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Contact restorationspecialties.com and you'll get the right answer and good parts.
Re: laytex or rubber? which one would you use? [Re: hotairballoonpilot] #955194
03/21/11 08:40 PM
03/21/11 08:40 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've probably bought 50 trunk weatherstrippings from Classic (or more) for first gen Camaros. (I'm a dealer there and buy abit to ship to Oz and use on cars we are doing up)
I normally just get the cheaper ones, but did try one of the latex ones for a higher end car I built for my buddy....
From memory, the latex one had almost a skin to it versus the rubber one, and think (been a little while) that it did 'clip' into and hold a little better into the trunk rail better than the cheaper ones normally do.
The cheaper ones, you do have to slam the trunk abit as well, as they seem a little bit firm.
Re: laytex or rubber? which one would you use? [Re: OzHemi] #955195
03/21/11 08:58 PM
03/21/11 08:58 PM
South Dakota
South Dakota
thanks oz! Thats what I was wondering. Thinks its worth the extra 50 bucks?
Re: laytex or rubber? which one would you use? [Re: hotairballoonpilot] #955196
03/21/11 09:52 PM
03/21/11 09:52 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I only used the expensive ones once, and didn't bother with the extra cost since
Guess since the trunk doesn't get used much never really worried about it? And was not like a huuuuuuuuge difference to them from memory.
If I was doing a car to keep for myself I might consider the better ones perhaps, but I'd run down to Classic and give both styles a 'feel' again to refresh my memory. Only been buying the cheaper ones over the years made me forget 100% what the others were like.
I know the roof rail weatherstrippings fit nicely in my opinion, but not sure what style they would consider them compared to the two styles of trunk ones.
Re: laytex or rubber? which one would you use? [Re: OzHemi] #955197
03/21/11 09:57 PM
03/21/11 09:57 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
BTW...I believe the latex are supposed to more similar to the factory ones, where the rubber ones look a little different (think the latex had that like skin to them? or visa-versa)
And the latex might have been a tad softer as well.
