1957 Plymouth Build Video #955127
03/21/11 11:39 AM
03/21/11 11:39 AM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Someone mentioned that the 57/8 Plymouths made great customs and they are right I’ve seen a few that were very nicely done.
I personally think they make very nice hot rods. Thought I’d put up a link to the build video of my 57 Plaza in case anyone is interested.
Yeah, it’s red and white (I like Red and White) but it ain’t no Christine.
http://www.youtube.com/watch?v=ltjeyXTzkzw
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 1957 Plymouth Build Video [Re: Mike P] #955128
03/21/11 02:16 PM
03/21/11 02:16 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Definitely a cool car.
Re: 1957 Plymouth Build Video [Re: Mike P] #955129
03/25/11 06:24 PM
03/25/11 06:24 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Heck ya! Are those PAW valve covers? What intake is that? As in what brand, it looks cast iron almost. I love early Hemis.
Moparlee
Re: 1957 Plymouth Build Video [Re: Robbins] #955130
03/25/11 10:41 PM
03/25/11 10:41 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
As far as the valve covers I'm not real sure, it was one of those E Bay deals several years ago.
The intake is cast iron and originally built by Chrysler. It started life as an industrial 2BBL intake. As far as I can tell it was modified back in the late 50’s-early 60’s, probably with one of the old “U Fab it” kits. Whoever did it did a take wonderful job. The holes into the outer runners look like they were milled instead of hacked and the brazing is very nice.
It was originally set up to take three 3 bolt Stromberg/Ford carburators. I modified it to accept a large base Rochester center and 2 small base Rochester outboard carbs.
The setup works great and was worth putting a hole in the hood and adding the hoodscoop to make it fit.
Re: 1957 Plymouth Build Video [Re: Mike P] #955131
03/25/11 10:43 PM
03/25/11 10:43 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Another picture. The way it was modified maintains the integrity of the dual plane design (and works great for bottom end torque).
Re: 1957 Plymouth Build Video [Re: Mike P] #955132
03/26/11 10:02 PM
03/26/11 10:02 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Cool! I love the car too.
Moparlee
Re: 1957 Plymouth Build Video [Re: Robbins] #955133
04/07/11 10:19 PM
04/07/11 10:19 PM
dart1962_440 Offline
Nice car!!
Re: 1957 Plymouth Build Video [Re: Mike P] #955134
04/08/11 10:27 PM
04/08/11 10:27 PM
jersey
Spaceman Spiff Offline
jersey
Sweet, good to see a fellow Forward looker here.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 1957 Plymouth Build Video [Re: Spaceman Spiff] #955135
04/10/11 03:30 AM
04/10/11 03:30 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
GREAT VIDEO,,, I can almost hear "you keep a knocken but you cant come in" some day ill learn how to post on you ttube,,,
falcon hood scoop nice touch,,,,
QUESTION,,, how do you like those expandable freeze plugs ?? any problems with them ? i have an early hemi with one freeze plug bore/boss problem,,thanks in advance
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1957 Plymouth Build Video [Re: fstfish66] #955136
04/10/11 07:12 AM
04/10/11 07:12 AM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Actually it's a T Bird scoop (same style, but a bunch larger than the Falcon ones). I really didn't want to cut the hood but there was no way around it if I was going to run the Tri-Power.
I've got the Freeze plugs in 2 engines and have had no problems with them.
Re: 1957 Plymouth Build Video [Re: Mike P] #955137
04/13/11 12:33 PM
04/13/11 12:33 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
thanks im going to pm you,,,
2015 cherokee
2013 R/T classic
