4.30 gears ??
#955050
03/21/11 09:17 AM
03/21/11 09:17 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
First thanks Dr DIFF for responding as fast as he does . Friend of mine is looking for (4.30 pro gears) for his dana 60 spool had 5.13s originally . Why is this such a problem with vendors . I see some don't show them ,others have special notes . I found a post from 2009 on moparts same senerio. Thanks Don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
Re: 4.30 gears ??
[Re: TheOtherDodge]
#955052
03/21/11 09:51 AM
03/21/11 09:51 AM
Posts: 2,177 ill
dennismopar73
ill
call rich saywer he ran 9s in the duster with 4.30s dana street gear for years same car roy edwards had,
Re: 4.30 gears ??
[Re: sg66mopar]
#955057
03/21/11 06:13 PM
03/21/11 06:13 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
I have US/Strange 4.30 pro gears in my Duster. They used to make them in "batches". If you were looking between batches, you were out of luck until the next run. I didn't know they went under.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
Re: 4.30 gears ?? update
[Re: 572charger]
#955059
03/23/11 10:44 PM
03/23/11 10:44 PM
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
The friend that was trying to locate the 4.30 pro gears call strange and is buying them through them directly. Buying them and receiving them .I wonder when . i'll post if when they get them . DR
new 9.96 131.82
6.23 108
1.30 60 foot
Re: 4.30 gears ??
[Re: JD Dart]
#955063
03/24/11 07:35 PM
03/24/11 07:35 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I am running 4.88 street gears over 150 passes all of them on a brake with the 60's in the low 1.3x at 3000# and so far they are fine.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 4.30 gears ??
[Re: DoctorDiff]
#955064
03/24/11 09:45 PM
03/24/11 09:45 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Yes, the only source was US Gear. Unfortunately the company went bankrupt several years ago and was recently bought by General Dynamics.
The new company, AxleTech is finally starting to ramp up the old US Gear product line.
Now we can get our Pro Gears and Submarines from one manufacturer
