4.30 gears ?? #955050
03/21/11 09:17 AM
03/21/11 09:17 AM
St. Louis Mo.
10 o to go Offline OP
"Happy Don"
"Happy Don"
St. Louis Mo.
First thanks Dr DIFF for responding as fast as he does .
Friend of mine is looking for (4.30 pro gears) for his dana 60 spool had 5.13s originally .
Why is this such a problem with vendors .
I see some don't show them ,others have special notes .
I found a post from 2009 on moparts same senerio.
Thanks Don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: 4.30 gears ?? [Re: 10 o to go] #955051
03/21/11 09:26 AM
03/21/11 09:26 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
When I was looking for 4.30 gears several years ago (7), they were not as easy to find then...I could only find street gears (but they worked fine on my low 9 second 3500 lb Challenger).
Im not sure why they are so difficult to find.
Re: 4.30 gears ?? [Re: TheOtherDodge] #955052
03/21/11 09:51 AM
03/21/11 09:51 AM
ill
dennismopar73 Offline
ill
call rich saywer he ran 9s in the duster with 4.30s
dana street gear for years
same car roy edwards had,
Re: 4.30 gears ?? [Re: TheOtherDodge] #955053
03/21/11 09:55 AM
03/21/11 09:55 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
There only made by U.S.Gear,distributed by Strange. I was told that the pro gears were out of production for a while,but they were going to receive stock shortly. I would give Strange a call and see if they came in.
Re: 4.30 gears ?? [Re: OUTLAWSSAA] #955054
03/21/11 01:58 PM
03/21/11 01:58 PM
sg66mopar Offline
sg66mopar  Offline
I've been looking for these for 2 years also. Dr. Diff said he would try to come up with some a couple months back but so far no word.
Re: 4.30 gears ?? [Re: sg66mopar] #955055
03/21/11 02:31 PM
03/21/11 02:31 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, the only source was US Gear. Unfortunately the company went bankrupt several years ago and was recently bought by General Dynamics.
The new company, AxleTech is finally starting to ramp up the old US Gear product line.
Re: 4.30 gears ?? [Re: DoctorDiff] #955056
03/21/11 04:25 PM
03/21/11 04:25 PM
sg66mopar Offline
sg66mopar  Offline
Thanks for the update DOC. That probably means there won't be any 4.30s in our lifetime.
Ford 9 inch might be in the crystal ball.
Re: 4.30 gears ?? [Re: sg66mopar] #955057
03/21/11 06:13 PM
03/21/11 06:13 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I have US/Strange 4.30 pro gears in my Duster. They used to make them in "batches". If you were looking between batches, you were out of luck until the next run. I didn't know they went under.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: 4.30 gears ?? [Re: nhramark] #955058
03/22/11 08:14 AM
03/22/11 08:14 AM
pa
572charger Offline
572charger  Offline
pa
street gear [ 4.30] in my charger runs 9s all day long ? but i would not run a pro gear because i drive on the street , never had a problem with street gears
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 4.30 gears ?? update [Re: 572charger] #955059
03/23/11 10:44 PM
03/23/11 10:44 PM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
The friend that was trying to locate the 4.30 pro gears call strange and is buying them through them directly.
Buying them and receiving them .I wonder when .
i'll post if when they get them .
DR
Re: 4.30 gears ?? update [Re: 10 o to go] #955060
03/23/11 11:39 PM
03/23/11 11:39 PM
sg66mopar Offline
sg66mopar  Offline
Well, that'll be interesting to see. I've talked to them also, although not recently.
Sure would like to get some.
Re: 4.30 gears ?? update [Re: sg66mopar] #955061
03/23/11 11:58 PM
03/23/11 11:58 PM
ill
ill
Re: 4.30 gears ?? [Re: TheOtherDodge] #955062
03/24/11 02:58 AM
03/24/11 02:58 AM
WA
JD Dart Offline
JD Dart  Offline
WA
My 4.30 street gears worked fine for awhile but after 360 passes and 160 of those were with a transbrake in my car they lost 13 teeth on the ring gear I want my money back. This is why I went with a ford 9" gear selections are not a problem
best so far 8.53 @ 158.59 MPH 60'1.240
Re: 4.30 gears ?? [Re: JD Dart] #955063
03/24/11 07:35 PM
03/24/11 07:35 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I am running 4.88 street gears over 150 passes all of them on a brake with the 60's in the low 1.3x at 3000# and so far they are fine.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 4.30 gears ?? [Re: DoctorDiff] #955064
03/24/11 09:45 PM
03/24/11 09:45 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Now we can get our Pro Gears and Submarines from one manufacturer
Re: 4.30 gears ?? update [Re: 10 o to go] #955065
03/28/11 08:00 AM
03/28/11 08:00 AM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
DR
He got his gears a couple of days after ordering them .Cost around $290.00 $15.00 shipping .
Bought directly from U.S /Strange .
DR
