727 Question #955008
03/21/11 03:55 AM
03/21/11 03:55 AM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
Will everything in a big block 727 fit into a small block 727
Re: 727 Question [Re: KY Charger] #955009
03/21/11 10:18 AM
03/21/11 10:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes , assuming they are of the same vintage , meaning you can't stick the guts from an early 727 with the push button shifter and rear pump into a later 727 case .
