Re: Eddy heads on basically stock 440...
[Re: RapidRobert]
#954932
03/20/11 11:16 PM
03/20/11 11:16 PM
Posts: 3,691 MO
cdp
MO
I really would like to do the 440source heads rather than the Eddy's, but, I'd have to send them to someone for cleanup/inspection before bolt on. Which everyone seems to recommend.
The eddy's you don't. So, toss up. If there were a really reliable person here in KC I could trust with the 440source's, I'd probably go with them.
The cam, t-chain, headers I already have. I made a mistake on the cam, Its a comp XE274.
The 440 isn't apart yet, but I'm assuming the pistons are about .085 or so in the hole on a stock LP 70-440.
[Re: cdp]
#954937
03/21/11 09:05 AM
03/21/11 09:05 AM
Posts: 2,826 NY usa
540challenger
NY usa
I must stress this any aftermarket part should be inspected before bolting it on/in a motor. There was a thread just last we about the an eddy head ahving an issue that needed to be corrected from OTB. BE it the eddy or 440 source get it checked out. Heck you could always buy the head thorugh one of the engine builders on here have them inpected and shipped to you.
[Re: 540challenger]
#954940
03/21/11 10:52 AM
03/21/11 10:52 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
don't assume anything is ready to go as sold .
Another thing you need to do if you are going to run manifolds is to put a gasket on the heads and make sure the gasket does not overhang the ports , then put the same gasket on the manifolds and make sure the openings are at least as big if not a little bigger than the gasket openings . I just did this and found the manifold ports as much as a 1/4" smaller than the gasket opening , especially the end ports.
[Re: cdp]
#954941
03/21/11 08:47 PM
03/21/11 08:47 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I have a stock 70-440 take out motor that is low miles and in excellent condition.
My thoughts are to keep the stock shortblock, except a 268XE Comp cam, a CH4B intake, 3310 holley, factory magnum manifolds, and stock Eddy heads with a true dual exhaust.
With proper tuning, can I expect 400 HP?
Anyone else use Eddy's on a relatively stock motor?
I do have a good set of headers also, but would prefer to use the manifolds.
All going in a 66 Coronet.
Yes - you can achieve 400 hp with what you plan without the headers. Make sure that it is a true 10:1 CR, maybe 10.2:1 when you are done and feed it with a good carb. It might also respond well to milling the divider or adding an open spacer. Test to know for sure.
Depending on weight, converter, gear and tire, you may or may not be able to get into the 12's.
[Re: BSB67]
#954942
03/21/11 09:13 PM
03/21/11 09:13 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
Yep! And you'll then have a car that would REALLY gain some power with headers.
[Re: cdp]
#954943
03/21/11 09:22 PM
03/21/11 09:22 PM
Posts: 12,247 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
A few years ago I bolted a box stock set of Eddies on my old weary 440 that had a mild Hughes cam. At that time the big debate was whether the al. heads would loose more power than they would add due to the effective lower comp on the al. heads. That 440 was very tired and the OE comp was probably 8.5 or something.
I'll tell you how tired the thing was, it would blow the dipstick an inch or so out of the tube whenever I would wind it up. It had that much blow-by.
But the head swap alone netted a solid .25 sec difference in the 1/8 and picked up nearly 3 MPH. The car weighed 3,500 with me so you can figure the HP increase from 8.1 to 7.8.
Master, again and still
