The XE274 looks like its in the right ballpark for your goals... about 230 intake duration @.050. The rest comes down to details - which can make power.
The mechanical flat tappet - MP .528 or other - can help with the added expense of adjustable rockers. If you go that route, suggest ductile iron Crane's or Comp "pro magnum" for durability.
