Re: new edelbrock heads vs. my pro parts headers
[Re: turner]
#954808
03/20/11 09:52 PM
03/20/11 09:52 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
I had no problems w/E heads/spark pug and ppheader interference. Just need patience and an extra send of arm joints for 5/7. Or just yank the starter. (low deck/manual trans)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: turner]
#954809
03/20/11 10:07 PM
03/20/11 10:07 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
I made the mistake of trying to use a set of the original Pro Part headers on my 1969 383 Dart GTS 4 speed car they where not designed to be used on low decks in A bodys High deck motors only I'm not sure about the new ones Mazolini is selling now I ended up buying a set of the MustangEDITED, There Maddod headers, not Mustangs, sorry ) two inch low deck headers for that car, I haven't gotten around to swapping them into the Dart yet, maybe this spring I'm planning on installing them to check the fit and if I like them I will take them back off and have them coated black like the Pro Parts are now
[Re: Cab_Burge]
#954810
03/20/11 10:18 PM
03/20/11 10:18 PM
oldiron
New Hampshire, USA
yep, weren't designed to fit ld motors. reformatted #7 downpipe to clear clutch linkage (stock) and double gaskets, other than that they fit ok
[Re: moparniac]
#954812
03/20/11 10:50 PM
03/20/11 10:50 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use the same set of Pro Parts headers on both 383 and 440 in my car.Only plugs that are harder than the rest are 5 and 7,which I get from under the car.
[Re: turner]
#954815
03/21/11 12:41 AM
03/21/11 12:41 AM
Cab_Burge
I've used a set of Hooker fenderwell two inch primary pipe on both my 1971 Duster with two different motors,440 and 400 stroker, with Eddy RPM heads and the 1969 Dart with a 440 with iron heads and the 383 before taking them off I would put the heads on and try the headers, worst case scenario is there are problems Probally not as no one has bruoght that up on here that I can remember Maybe that is why no one has said anything else
