SB eliminating coolant bypass hose #954524
03/20/11 02:04 PM
03/20/11 02:04 PM
South Lyon, Michigan
6bblRoadrunner Offline OP
I saw a post on here awhile ago about eliminating the coolant bypass hose and can't seem to find it. I'd like to get rid of mine. Any downsides to eliminating it? Do you run some sort of restrictor in place of the thermostat or a thermostat with a few holes drilled in it? This is for a car that see's limited street use.
Re: SB eliminating coolant bypass hose [Re: 6bblRoadrunner] #954525
03/20/11 02:08 PM
03/20/11 02:08 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I run a restrictor disc with 5/8" hole.
If you like drag racing, support your local track.
Re: SB eliminating coolant bypass hose [Re: CHAPPER] #954526
03/20/11 02:41 PM
03/20/11 02:41 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
If you have a thermostat you slould not eliminate the by-pass hose. I have a by-pass hose on mine even with a mez electric water pump. There is zero gain to eliminating the by-pass other than giving motor a cleaner look.
Re: SB eliminating coolant bypass hose [Re: 6bblRoadrunner] #954527
03/20/11 03:41 PM
03/20/11 03:41 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
on my drag only car i eliminated the bypass hose and run no thermstat with electric water pump and have no problems at all..
