dipstick length #954474
03/20/11 01:28 PM
03/20/11 01:28 PM
Cumberland County, NJ
coronetkid Offline OP
are the oil oil dipsticks for a 318LA and a 360La the same...interchangeable?
Re: dipstick length [Re: coronetkid] #954475
03/20/11 02:11 PM
03/20/11 02:11 PM
yes you're good
Re: dipstick length [Re: RapidRobert] #954476
03/20/11 02:45 PM
03/20/11 02:45 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Ive never had 2 of the exact same length.
What i do is change the oil on level ground. Run the engine enough to circulate the oil and then let it sit for a little bit. Now when you pull the dipstick out, mark the "full" level and scribe it with a grinder or drill a tiny hole there.
You can measure down and mark the 1 QT low mark as well....
Re: dipstick length [Re: wally426ci] #954477
03/20/11 04:54 PM
03/20/11 04:54 PM
md
mopars4ever Offline
mopars4ever  Offline
md
As long as you use the corresponding tube. Depending on the year engine, make and model the sticks and tube lengths vary. If your tube is the same length as the one you removed the stick from then you should be good to go.
Re: dipstick length [Re: mopars4ever] #954478
03/20/11 06:45 PM
03/20/11 06:45 PM
thanks guys
