Re: fuel lines
[Re: Rich970]
#954471
03/20/11 02:24 PM
03/20/11 02:24 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I`ve bought from both and can`t tell the difference. I believe it to be the same MIL spec. I`ve got -10 from the pump to the reg. Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: fuel lines
[Re: Rich970]
#954473
03/20/11 06:31 PM
03/20/11 06:31 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
hi i am running new fuel line braided stainless pump to carb. is there a difference in brands like Russell, Earls, Summit ? thanks
Like all things that are sold, some are good and some are not Not all stainless covered hoses meet the MIL specs for fuel. I like and use the teflon lined SS hoses for fuel, oil and as many other things I can use them on because there way better on pressure, corrosion and fluid resistance damaging them. I had a piece of AN neopreme SS fuel hose go bad, staring leaking in the middle of the hose , in six months. I've never had a teflon lined hose leak, the same size teflon lined SS hose is quite a bit smaller in diamter and weight than the same size neopreme,caomparing #8 to #8 Neopreme is usually cheaper per foot, same thing on the fittings also Buy it once or buy it several times
