Timing Chain Removal?
#954370
03/20/11 10:41 AM
03/20/11 10:41 AM
Posts: 114 Mashpee,MA
mopar360
Can't start my lawn mower
Mashpee,MA
Hey guys, So im taking apart my 360 ci. engine for overhaul and im at the timing chain, is there a certain puller needed to remove it? Any tips on removal are wanted. Thanks, Ethan
All throttle...No bottle!
1979 Chrysler 300 (360)
1984 Chrysler 5th Avenue (318)
Re: Timing Chain Removal?
[Re: mopar360]
#954371
03/20/11 11:18 AM
03/20/11 11:18 AM
RapidRobert
can use a gear puller on the crank gear just put something on the bolt hole threads to protect them but prob can CAREFULLY wedge it w 2 screwdrivers to get it started moving forward. Just use care as to not gouge anything
[Re: RapidRobert]
#954372
03/20/11 05:09 PM
03/20/11 05:09 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the cam gear and the crank gear need to move forward together other wise ..one will bind the other and nothing will move.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
