A Body Spindles 9" - 10" ? #954363
03/20/11 10:24 AM
03/20/11 10:24 AM
Beeton Ontario. Canada
BigSugar Offline OP
BigSugar  Offline OP
Hey Guys
I'm trying to locate a set of 73-76 A Body DRUM Spindles. I've been asked if I need a set from a (9" drum car or a 10" drum car,
Was there a spindile diameter change in the 9 - 10" drum brake cars ?
(A Body)
Ron
Re: A Body Spindles 9" - 10" ? [Re: BigSugar] #954364
03/20/11 03:33 PM
03/20/11 03:33 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
The bearings are different sizes from the 9 to 10 brakes, so the spindle has to be different. I don't have one apart to measure. You could get a bearing ID mearsure front a auto parts store for reference.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: A Body Spindles 9" - 10" ? [Re: BigSugar] #954365
03/20/11 03:57 PM
03/20/11 03:57 PM
AndyF Offline
AndyF  Offline
Are you doing the Viper brake swap? The drum knuckle has a larger inner wheel bearing in 1973. That allows you to run the 11.75 rotors directly on the drum knuckle spindle. It isn't the size of the brakes that matters, it is the size of the inner wheel bearing. Although I do believe that the 10 inch drums only came on the later spindles with the larger bearings.
Re: A Body Spindles 9" - 10" ? [Re: AndyF] #954366
03/20/11 04:11 PM
03/20/11 04:11 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Ron.
I sent you a PM.
Jim V.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: A Body Spindles 9" - 10" ? [Re: hemi71x] #954367
03/20/11 05:44 PM
03/20/11 05:44 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Pretty sure the 9" drum disappeared in '73 when the big bolt pattern came around on the A bodies.
Re: A Body Spindles 9" - 10" ? [Re: slantzilla] #954368
03/20/11 05:45 PM
03/20/11 05:45 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Nope , 6 bangers still got them ... AND 4" bolt pattern , in 73 anyway ...
Re: A Body Spindles 9" - 10" ? [Re: JohnRR] #954369
03/20/11 06:09 PM
03/20/11 06:09 PM
BigSugar Offline OP
BigSugar  Offline OP
I't's like this...Now that I'm looking for a set of A body Drum spindles they've vanished ! Tying to find them locally and save a big Shipping Charger.
Thanks Andy Yes I'm doing the Viper Caliper conversion, Found my Calipers for $250 ,(9000 miles fresh), in California Shipping them came in at another $75. So I'm hoping to find a set of Spindles a bit closer to Ontario Canada. But All I seem to be finding are the 9" drum spindles.
Ron
