starting a 440 that has been sitting a while? #953916
03/19/11 07:19 PM
03/19/11 07:19 PM
central new york
pettyblue440 Offline OP
central new york
I have a 440 that was rebuild and driven maybe 1500 miles. It had a stock rebuild, valve job, hyd cam, 30 over cast pistons, yada yada. I had it in a car and pulled it to put a 340 in. It has been sitting in the garage for 3-4 years. I never drained the oil or backed off the valve train in this time. I have ocassionally pulled the engine over. What should I plan on doing before I run this again? I am mainly concerned about sludge or rust. Thanks, Jon
Re: starting a 440 that has been sitting a while? [Re: pettyblue440] #953917
03/19/11 07:29 PM
03/19/11 07:29 PM
Ch oilfilter/preoil w the 5/16" hex/spray WD40 in the cyls & hand turn it over to lube all of the cyl (do b 4 preoiling & the turning over to hit the heads will take car of that)/no opinion on the valve spring situation but I'd probably go as is
Re: starting a 440 that has been sitting a while? [Re: RapidRobert] #953918
03/20/11 02:57 PM
03/20/11 02:57 PM
central new york
central new york
thanks, anyone else?
Re: starting a 440 that has been sitting a while? [Re: pettyblue440] #953919
03/20/11 03:12 PM
03/20/11 03:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You would be okay firing it as-is, but if you're concerned about it, then lube the cylinders with wd40 and pull the distributor and prime it with a hex shaft while having a helper spin the crank over a few times with a ratchet.
Re: starting a 440 that has been sitting a while? [Re: pettyblue440] #953920
03/20/11 03:37 PM
03/20/11 03:37 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I agree w/ WD 40 in the cylinders & priming it by hand. My 383 mag was sitting for 6-7 yrs on a stand & when we installed in my 71 Power Wagon, I changed the oil twice, put Marvel Mystery oil in the plug holes & a week later we used WD 40 & primed it by hand. Fired right up w/ good oil pressure. Changed the oil again & runs like a new motor.
Re: starting a 440 that has been sitting a while? [Re: pettyblue440] #953921
03/20/11 04:08 PM
03/20/11 04:08 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Just make sure you prime the oil system so it puts oil to the lifters and lifter lobes.
Re: starting a 440 that has been sitting a while? [Re: Dodgem] #953922
03/20/11 04:14 PM
03/20/11 04:14 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
I am going to fire the 440 in my 62 in April or so. It has not run in 5 or so years ....
In additional to the above ...I am going to pull the rockers and check the V-springs .... just them with a rubber hammer.
I had a friend that fired a 440 in a motor home that had sit for awhile. The VS had broke ... and the valve dropped into the cylinder.
