MSD question #953844
03/19/11 05:45 PM
03/19/11 05:45 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I have a question about an MSD "Soft Touch" rev control. I bought one used and it has two plug -in chips in the rear, one is for max rpm (7000) and the other is for No. of Cylinders. Question is how do you tell which cylinder chip it has ( there are no markings on it)? Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: MSD question [Re: rattler] #953845
03/19/11 07:02 PM
03/19/11 07:02 PM
I dont know MSD so just thinking out loud: What color is it? There's gotta b some way to visually ID them
Re: MSD question [Re: RapidRobert] #953846
03/19/11 07:08 PM
03/19/11 07:08 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Rattler,check with MSD, The only soft touch modules I seen you have to cut a wire for # of cylinders if not 8. Are your sure it's not a two step?
Re: MSD question [Re: jvcuda] #953847
03/19/11 10:09 PM
03/19/11 10:09 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
This is a Soft Touch meant for a MSD 6-T, the No. Cyl. chip is a dark burgundy color and the rpm chip is white. I'll post a couple of pics. Randy
Re: MSD question [Re: rattler] #953848
03/19/11 10:15 PM
03/19/11 10:15 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Another from the back.
Re: MSD question [Re: rattler] #953849
03/20/11 11:22 AM
03/20/11 11:22 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Bump back to the top.
Re: MSD question [Re: rattler] #953850
03/20/11 02:23 PM
03/20/11 02:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Pretty sure you have an old obsolete unit. The 8738 replaced that unit 15 to 20 years ago.
Re: MSD question [Re: NITROUSN] #953851
03/20/11 02:36 PM
03/20/11 02:36 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Randy, yeah that's an old control.Can you check with the seller? Best bet would be to check with msd. good luck, john
