Cummins engine vs. typical engine hoist #953696
03/19/11 01:47 PM
03/19/11 01:47 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
I scored a 5.9 cummins to put in my truck. I'm very excited that this part of the project is finally coming to fruition. But I'm realizing, that only working with big blocks, this thing is like one stage larger. Will a typical engine hoist like the one I have be adequate? Mine's rated for 2000 lbs, which nominally says I should be good. It lifts fully assembled big blocks without issue. But... what do you guys think about handling the cummins?
"Broke is temporary, cheap lasts forever"
Re: Cummins engine vs. typical engine hoist [Re: 68Bullet] #953697
03/19/11 01:49 PM
03/19/11 01:49 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
effen it is a China-Mart one .... watch OUT ...
Re: Cummins engine vs. typical engine hoist [Re: 68Bullet] #953698
03/19/11 01:51 PM
03/19/11 01:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hmm, i once bought an engine stand\d, rated for something like 2000 lbs, even had a picture of a BB Mopar with B1 heads on the box.
Put my stock 413 on it and boy did it groan, but it held long enough for me to pull the heads and all accessories. Anyway, this was made "overseas" and was optimistically rated I am thinking. I just hope yours isn't rated "optimistically".
Don't be the exception.
Re: Cummins engine vs. typical engine hoist [Re: Supercuda] #953699
03/19/11 02:32 PM
03/19/11 02:32 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
I do have some faith, as I picked mine up over 10 years ago from a legitimate parts store. Which doesn't guarantee quality .... But the glut of poorly made stuff today makes me have just a little more faith in my old trusty.
I also agree with the engine stand comment, my engine stand sure doesn't like a fully assembled big block, but so far hasn't crumbled yet!
Re: Cummins engine vs. typical engine hoist [Re: 68Bullet] #953700
03/19/11 03:05 PM
03/19/11 03:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A Cummins weighs in the neighborhood of 1200lbs so your 2000lb hoist should be fine .
Re: Cummins engine vs. typical engine hoist [Re: JohnRR] #953701
03/19/11 03:21 PM
03/19/11 03:21 PM
IN
ahy Offline
ahy  Offline
IN
The rating can depend on how far the arm is extended. Some are rated with the lift arm partially extended and handle less at full extension. If it is rated 2000 lb at full extension you should be fine.
Re: Cummins engine vs. typical engine hoist [Re: 68Bullet] #953702
03/22/11 01:58 AM
03/22/11 01:58 AM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
Follow up report: Engine hoist wins! Lifts that heavy sucker like a champ! And most importantly, keeps me from getting hernias when I have to move stuff.
Re: Cummins engine vs. typical engine hoist [Re: 68Bullet] #953703
03/22/11 02:58 AM
03/22/11 02:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I've used engine hoists to move all sorts of things. One was a complete front axle assembly: A Dana 44 for a Dodge, complete with rotors and calipers.
I had an engine hoist failure ONCE! I was pulling my first Big Block Mopar... a 400 from a 72 Newport. The motor was nearly complete and the 727 was still attached. Just as I had the whole thing out and past the core support, the ram BENT like a boomerang and the whole shebang slammed to the ground! The trans case cracked along the bellhousing and the oil pan was smashed. I was lucky to be clear of the freefall.
At the time I thought that the motor was a 440, which is what I wanted. When I pulled the A/C pump, I found out that it was a 400. Standard bore too. It was the desireable 0230 thick wall 400 block! I paid $175 for the entire car. I sold the bare block for $400!
Re: Cummins engine vs. typical engine hoist [Re: 68Bullet] #953704
03/22/11 10:13 AM
03/22/11 10:13 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
This is slightly off-topic, but, when I was looking for a new engine stand a few years ago, I only looked at the ones rated for 2,000 lbs. Basically, no matter who it came from or who's name was on on it, they all looked like they came from the same source in China. Absolutely pure crap where the 2,000 rating was a big stretch. Unfortunately, it seemed the only step up was $1,000 units and nothing in between. So I bought a $200 Torin (still pure crap) and I wish I hadn't. It's already toppled over twice.
We no longer have a choice anymore. Chinese junk or commercial stuff too expensive for an individual. Recently I had the same experience on a MIG welding cart. Sheesh!
Re: Cummins engine vs. typical engine hoist [Re: Commando1] #953705
03/22/11 06:27 PM
03/22/11 06:27 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
We made this bed we're in...
As far as not affording it... It fell over twice? My insurance deductable on the car, and my medical, would eat up the difference between a cheap one and a solid one. You beat the odds twice. Wait until the third time when an ear breaks off the engine...
Re: Cummins engine vs. typical engine hoist [Re: moper] #953706
03/22/11 08:50 PM
03/22/11 08:50 PM
Commando1 Offline
Commando1  Offline
Yes, Iknow Ibeat the odds and I'm not thrilled about, but, the insinuation that the cheap route was taken is blatently wrong!
Ihave 2 engineering degrees where Ilearned about cost/benefit ratio INTIMATELY and a $1,000 unit for a hack in his garage doesn't make sense. My wife needs food and a roof over her head. The mid market has vanished leaving us with a choice between crap and super-premium. Look back at all the threads about tools, furniture, etc. The rich have won by elliminating the middle class.
Re: Cummins engine vs. typical engine hoist [Re: Commando1] #953707
03/22/11 09:00 PM
03/22/11 09:00 PM
IN
ahy Offline
ahy  Offline
IN
A few years ago I was in the same situation with an engine stand. I bought a "1000 lb" cheap one and wasn't sure I liked the look of it. I decided to test it with my fully dressed 318 takeout before putting a BB on it. I bolted up the engine and slowly let the hoist down. It went down and down and down as the backplate bent. I guess it was rated 1000 lbs with overall engine length not to exceed 5 inches or something. That one got returned and I looked at WW Grainger. Turns out they have (or had) a good "middle line". I bought a 1200 lb stand at reasonable cost. Very stout and wasn't bothered a bit as my BB came together. I believe this one could handle a real 1200 lb engine.
Point is its worth checking WW Grainger.
Re: Cummins engine vs. typical engine hoist [Re: ahy] #953708
03/23/11 12:16 AM
03/23/11 12:16 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Harbor Freight breakdown model. Hasn't failed me yet, knock on wood. picked a 225, 318, 360, 408, 451 and a Dodge Cummins Turbo-Diesel, With trans! BUT it did lose a wheel under the Cummins, one of the front ones. I wasnt there, but it was kinda scary from what I heard. Mine has the support bands from the rear legs up to the top of the ram. And I ditched the no grade fasteners for grade 8 bolts, the big ones. I can take it down and fit it in the back seat of my car, kinda cool. Needs a handle in the back though and better casters up front. When the guy broke the cast iron front caster wheel, he replaced them with hard rubber that seem harder to pivot naturally. Since it is a break down its a little less sturdy than a welded rigid frame, but I have a flat polished concrete floor so there is no bumps to make it rock and roll. Looks identical to American Tool, The one at NAPA, O'reilly and Pep Boys. Some have the straps, others do not but everything else is the same. BE SAFE! Anything can break...
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
