727 COOLING FOR HOT STREET DRIVING??? #953645
03/19/11 12:14 PM
03/19/11 12:14 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
Anyone have thoughts on the best cooling tricks for my 727 on the street. 69road runner 500 ci 440 727w/ ultimate converter 4:10 gears. P.S. fresh rebuild what tranny fluid??? Thanks Nick
Re: 727 COOLING FOR HOT STREET DRIVING??? [Re: runner12] #953646
03/19/11 12:26 PM
03/19/11 12:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you dont have any OD you could use the B&M super
cooler... I just use cheapo type F fluid
Re: 727 COOLING FOR HOT STREET DRIVING??? [Re: MR_P_BODY] #953647
03/19/11 01:29 PM
03/19/11 01:29 PM
If you dont have any OD you could use the B&M supercooler... I just use cheapo type F fluid
If you don't have a deep tranny pan already get one and a trans temp gauge before spending any money on a additional tranny cooler. You may find out you don't need another tranny cooler Trans fluid nneds to be run at or above 160F for the additives in iti to work, it doesn't start breaking chemically until it gets close to 300F My message is if your tranny fluid runs below 250F all the time, don't worry about it
Re: 727 COOLING FOR HOT STREET DRIVING??? [Re: Cab_Burge] #953648
03/19/11 01:32 PM
03/19/11 01:32 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have a 8" converter and temp is 180 or less all the time.
with just a B&M cooler.
Re: 727 COOLING FOR HOT STREET DRIVING??? [Re: 70blackfish] #953649
03/19/11 05:36 PM
03/19/11 05:36 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
I burnt one up last year , I want to be xtra carful this year.
Re: 727 COOLING FOR HOT STREET DRIVING??? [Re: 70blackfish] #953650
03/19/11 05:45 PM
03/19/11 05:45 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
180 ? ...where do you take that reading ?
Re: 727 COOLING FOR HOT STREET DRIVING??? [Re: dOoC] #953651
03/20/11 01:39 PM
03/20/11 01:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Type-F don't have no additives.
I like to run the one through the radiator if it has a radiator cooler then when it comes out run it into at least a small radiator type cooler and back to the trans. A high stall converter and big TQ engine and low gears is gonna generate a lot of heat, got to get rid of it some how.
