UCA Moog problem solver bushing help needed...
#953591
03/19/11 11:11 AM
03/19/11 11:11 AM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
I am getting ready to press on the UCA bushing on my '68 Coronet. I have a set of the the normal UCA bushings and a set of the problem solvers. The problem solvers have a couple what looks like washers included in the kit. The normal kit does not. I don't remember the washers when I tore this apart awhile back. Do I use them and what are they for? Thnx for the help. Chuck ![](http://images53.fotki.com/v140/photos/3/313373/6206742/UCABushings-vi.jpg)
Re: UCA Moog problem solver bushing help needed...
[Re: moparrulzzz]
#953592
03/19/11 11:30 AM
03/19/11 11:30 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
The washers slip on to each side of bushings before you slide arm back into frame mount tabs. Should be 8 total for both upper arm kits. ![](/ubbthreads/images/graemlins/Twocents.gif) If not 8 in kit, then you at least have to put one on each end as shown in your image.
[Re: buildanother]
#953593
03/19/11 12:39 PM
03/19/11 12:39 PM
moparrulzzz
Mansfield,Ohio
The washers slip on to each side of bushings before you slide arm back into frame mount tabs. Should be 8 total for both upper arm kits. If not 8 in kit, then you at least have to put one on each end as shown in your image.
Ok that makes sense. The lip on each washer goes thru the frame mount tabs and the flat rides on the bushing itself. I wonder why the kit for the normal UCA bushing didn't have the washers? I do have 8 total. Thnx !!!!! Chuck
[Re: Ronnman]
#953595
03/20/11 12:12 PM
03/20/11 12:12 PM
moparrulzzz
Mansfield,Ohio
The flat side of the washers face out on each of the bushings.
Ok after looking at my normal UCA bushings they do have those washers they are attached to the bushing itself. Do I need to press those washers onto the bushing or just installthem loose with the UCA? They don't just fit onto the bushing looks like they need to be pressed on as well... ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: autoxcuda]
#953600
03/21/11 11:08 AM
03/21/11 11:08 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
just wondering ( and not wanting to highjack the trhead but )
why not to FIX the frames or the area what makes to NEED those offset bushings ?
[Re: NachoRT74]
#953601
03/21/11 12:04 PM
03/21/11 12:04 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
The bushing let you get more positive caster.The factory never meant for them to use radial tire and the bushings attain it.You cant repair what wasnt there to start with.Rocky
Chrysler Firepower
[Re: NachoRT74]
#953602
03/21/11 03:35 PM
03/21/11 03:35 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
In the original poster case, he is actually not using them for thier original intended purpose. For increased postive caster you DO NOT use/follow the instruction in the kit.
You follow these modified instructions....
