UCA Moog problem solver bushing help needed... #953591
03/19/11 11:11 AM
03/19/11 11:11 AM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I am getting ready to press on the UCA bushing on my '68 Coronet. I have a set of the the normal UCA bushings and a set of the problem solvers.
The problem solvers have a couple what looks like washers included in the kit. The normal kit does not.
I don't remember the washers when I tore this apart awhile back.
Do I use them and what are they for?
Thnx for the help.
Chuck
Re: UCA Moog problem solver bushing help needed... [Re: moparrulzzz] #953592
03/19/11 11:30 AM
03/19/11 11:30 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The washers slip on to each side of bushings before you slide arm back into frame mount tabs. Should be 8 total for both upper arm kits. If not 8 in kit, then you at least have to put one on each end as shown in your image.
Re: UCA Moog problem solver bushing help needed... [Re: buildanother] #953593
03/19/11 12:39 PM
03/19/11 12:39 PM
Mansfield,Ohio
Mansfield,Ohio
Ok that makes sense. The lip on each washer goes thru the frame mount tabs and the flat rides on the bushing itself.
I wonder why the kit for the normal UCA bushing didn't have the washers?
I do have 8 total. Thnx !!!!!
Chuck
Re: UCA Moog problem solver bushing help needed... [Re: moparrulzzz] #953594
03/20/11 12:32 AM
03/20/11 12:32 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
The flat side of the washers face out on each of the bushings.
Re: UCA Moog problem solver bushing help needed... [Re: Ronnman] #953595
03/20/11 12:12 PM
03/20/11 12:12 PM
Mansfield,Ohio
Mansfield,Ohio
Ok after looking at my normal UCA bushings they do have those washers they are attached to the bushing itself.
Do I need to press those washers onto the bushing or just installthem loose with the UCA? They don't just fit onto the bushing looks like they need to be pressed on as well...
Re: UCA Moog problem solver bushing help needed... [Re: moparrulzzz] #953596
03/20/11 12:18 PM
03/20/11 12:18 PM
chicagoland,usa
chicagoland,usa
The way they are designed, it looks like they should easily push in there with jaws of bench vice, no?
Re: UCA Moog problem solver bushing help needed... [Re: buildanother] #953597
03/20/11 02:50 PM
03/20/11 02:50 PM
New York
rarefish Offline
rarefish  Offline
New York
I installed a set in my 68 Charger a couple of years ago. If you are installing them to get a more positive caster. Do not follow the instructions that came with the bushings. I can't remember if it was the front or the rear ones, but one pair is pressed in with the arrow facing the the opposite direction.
Re: UCA Moog problem solver bushing help needed... [Re: rarefish] #953598
03/20/11 10:35 PM
03/20/11 10:35 PM
Mansfield,Ohio
Mansfield,Ohio
Ok I have them installed per Ehrenbergs chart. I figured out that the reason the washers are not installed is so one can see the arrows on the bushing!
THNX ALL!!!
Re: UCA Moog problem solver bushing help needed... [Re: moparrulzzz] #953599
03/20/11 10:55 PM
03/20/11 10:55 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's a set that was installed on my Cuda for years.
Re: UCA Moog problem solver bushing help needed... [Re: autoxcuda] #953600
03/21/11 11:08 AM
03/21/11 11:08 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
just wondering ( and not wanting to highjack the trhead but )
why not to FIX the frames or the area what makes to NEED those offset bushings ?
Re: UCA Moog problem solver bushing help needed... [Re: NachoRT74] #953601
03/21/11 12:04 PM
03/21/11 12:04 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The bushing let you get more positive caster.The factory never meant for them to use radial tire and the bushings attain it.You cant repair what wasnt there to start with.Rocky
Chrysler Firepower
Re: UCA Moog problem solver bushing help needed... [Re: NachoRT74] #953602
03/21/11 03:35 PM
03/21/11 03:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
In the original poster case, he is actually not using them for thier original intended purpose. For increased postive caster you DO NOT use/follow the instruction in the kit.
You follow these modified instructions....
