Re: Indy EZ-1 piston to valve clearance?
[Re: Mopar_Ray]
#953554
03/19/11 11:04 AM
03/19/11 11:04 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
I have a similar build, except a solid roller. My P2V clearance was .120 intake, I'll have to look at my notes for the exhaust. It was plenty. I used playdough on the pison, oil on the valves, installed head gasket, torqued to 30 ft.-lbs. Then removed, cut the playdough in half, and measured. I probably did it in a very archaic way, but that's how I have done my small block strokers as well and it worked for me.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: ChrgrCuda]
#953555
03/19/11 11:51 AM
03/19/11 11:51 AM
Posts: 512 Illinois
Mopar_Ray
Illinois
Thanks, with hydraulic lifters they say to temporarily replace lifters with solids to check? Thats why I'm trying to figure if it will even be an issue. Kind of a pain to remove lifters just to check.
[Re: Mopar_Ray]
#953556
03/19/11 01:33 PM
03/19/11 01:33 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
It is always better to be safe than sorry Get the tools out and switch those two lifters and check the actual P to V clearances BTW, I'm running .060 P to V on my 440-1 headed 527 motor with a soilid roller cam, good valve springs(325lbs. on the seats and 830 lbs opened) and Harland Sharp rockers I like to see .080 but I'll live with .060 until it fails
[Re: Cab_Burge]
#953557
03/19/11 02:50 PM
03/19/11 02:50 PM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
And the pushrods will be significantly different for solids as opposed to hydraulics too.
[Re: Mopar_Ray]
#953558
03/19/11 03:13 PM
03/19/11 03:13 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Getting ready to replace heads. Going to from 906 heads to EZ-1 heads. I know I should check, but may not even be an issue? Motor is a 440/505 stroker. SRP flat top pistons. Piston deck height is .025 below. Comp XE295HL Hydraulic, 251/257 duration, 564/564 lift cam. Trying not to "over think" this, anyone have a similar build? Is this even going to be an issue?
for a person to accurately answer this question the ywould have to have the exact same engine as yourself , exact , deck height , piston in the hole , same heads and cam.
What is such a pain to pull a lifter? You have to pull the heads which requires the intake to be off , the lifters are right there , do you piston to valve check with intake off.
Don't forget you need to swap 2 springs to lightweight checking springs , there is your pain ...
[Re: JohnRR]
#953559
03/19/11 04:12 PM
03/19/11 04:12 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
Pardon by lack of knowledge, not worried about the "exact" clearance. But before pulling lifters, replacing with solids and swapping springs I thought someone might be running a flat top piston with a hydraulic cam. just want to know if its enough to get by until I move to a higher lift roller cam?
[Re: JohnRR]
#953560
03/19/11 05:11 PM
03/19/11 05:11 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I think the "pain" is having to buy 2 solid lifters and 2 checker pushrods !!
On the bright side, you're going to need the checker pushrods anyway since your head swap is going to dictate new pushrods.
And by the way, don't even think of running those EZ's "out of the box" if you got them from ICH. At LEAST blow all the passages clean and heve the valvejob checked.
[Re: Stanton]
#953561
03/19/11 05:44 PM
03/19/11 05:44 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
OK,OK I'l buy the the lifters. Know I need the checker pushrods. More worried about switching to checking springs. Heads while not being ported, are being checked by a hghly respected builder.
[Re: Mopar_Ray]
#953566
03/20/11 02:48 AM
03/20/11 02:48 AM
JohnRR
OK,OK I'l buy the the lifters. Know I need the checker pushrods. More worried about switching to checking springs. Heads while not being ported, are being checked by a highly respected builder.
you don't need to buy 2 lifters , you can take 2 of your hyd lifters apart , pull the guts and fill the space with small machine washers and putthe cup and retaining ring back in and use the pushrods you have ... But with EZ's you need longer pushrods, if you have a hollow pushrod you can make a checking pushrod by cutting it , tapping the insides and using a piece of fine thread threaded rod .
[Re: B G Racing]
#953569
03/20/11 08:56 AM
03/20/11 08:56 AM
Posts: 512 Illinois
Mopar_Ray
Illinois
If your .025 in the hole,pistons are flycut(valve reliefs) or dished and you use a .030 to .050 head gasket with the 78cc EZ head you will not have any problems with a cam under .600 lift.
Bob, Exactly who I hoped might reply to this question!
