Setting advance timing #953423
03/18/11 11:24 PM
03/18/11 11:24 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Finally got my first Timing Light.I have used one in high school and know how to set base timing.What I don't know how to do is set advance timing.I want to fiddle with it on my new 360 crate motor.Has vacuum advance distributor.And Total Timing refers to base plus advance? Thanks. larry
Facts are stubborn things.
Re: Setting advance timing [Re: larrymopar360] #953424
03/18/11 11:37 PM
03/18/11 11:37 PM
scratchnfotraction Offline
get a vac gauge to watch for the highest vac reading while your set the base timing
set it with the most vac you can then back it off one full #
example...19 pounds of vac is max,back it down to 18 and look to see where the base is set
test drive,advance it till it just has a slight ping on a hard wot blast
time light and set the idle air needles just go back and forth adjust curb idle and fine tunning it
way i duz it,i am at 14 base and 19-20 pounds of vac,curb idle at 850 rpms
i can stomp it to the floor and it wont miss a lick getting with it out the hole
good luck
Re: Setting advance timing [Re: scratchnfotraction] #953425
03/19/11 12:05 AM
03/19/11 12:05 AM
set it with the most vac you can then back it off one full # example...19 pounds of vac is max,back it down to 18 and look to see where the base is set
& keep slowing the idle speed to where you want it as you are bumping the timing. Then w that (1) initial figure in hand shorten the slots to get (2) 35 total (SB) w vac adv unhooked/capped for intial and total setting then w those set more on to (3) springs then (4) hookup/adj vac adv. More on them later.
Re: Setting advance timing [Re: RapidRobert] #953426
03/19/11 01:52 AM
03/19/11 01:52 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Re: Setting advance timing [Re: larrymopar360] #953427
03/19/11 06:27 AM
03/19/11 06:27 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes base + advance (excluding vacuum advance) = total timing.
Re: Setting advance timing [Re: DaytonaTurbo] #953428
03/19/11 08:50 AM
03/19/11 08:50 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
just lock it out and run it
Re: Setting advance timing [Re: scratchnfotraction] #953429
03/19/11 10:04 AM
03/19/11 10:04 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
good luck
vacuum is measured in inches not pounds.
