Fixing past mistakes sucks! - Update #953325
03/18/11 09:36 PM
03/18/11 09:36 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
The noise from my electric fuel pump is driving me nuts, so I am thinking of going back to a manual pump on my 360.
Back in the day, I ran a Holly chrome manual pump, but after several months of use, the pump arm and the eccentric were severaly worn. At the time I figured it was an issue with the pump and went to an electric pump.
After some careful thought, my educated guess is that the pump arm was worn due to an oiling issue, that is, the idiot that assembled the motor (me) did not put the bolts for the cam thrust plate in the right spots. Although the motor has been apart and reassembled since those early days, I am not sure if I reassembled it correctly, or even put the eccentric back on.
So, I think my next task is to tear down the front of the motor and have a look at the thrust plate bolts..Oh what fun! Somtimes doing things right is a real pain in the but!
Re: Fixing past mistakes sucks! [Re: CUDAJAS] #953326
03/18/11 09:55 PM
03/18/11 09:55 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
If you can find one (don't know if Mancini still carries them or not), there used to be Moly coated Mopar Performance eccentrics that were lower friction than the bare steel factory piece.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Fixing past mistakes sucks! [Re: GO_Fish] #953327
03/18/11 11:09 PM
03/18/11 11:09 PM
Drill a ~1/4" hole in the cam plate in front of the pass oil gallery (thru the round rough dimed sized nub) and a 1/64" (.015") hole right behind it in the mini freeze plug capping the front of the horizontle main oil gallery (pull the plug and get a new one & drill/deburr it then drive it in. This'll put a pressurized squirt onto the chain/gears/eccentric as opposed to the 1/8" drip in the OE top pass bolt. High zinc oil & check that the pump is not binding/arm is square & as said a good eccentric
Re: Fixing past mistakes sucks! [Re: CUDAJAS] #953328
03/18/11 11:21 PM
03/18/11 11:21 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
How exactly is your electric fuel pump mounted? It can make a huge difference in how loud it sounds?
Re: Fixing past mistakes sucks! [Re: jbc426] #953329
03/18/11 11:53 PM
03/18/11 11:53 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Hmm...its a Mallory 140, mounted on the rear shock cross member. It is fairly quiet, but there is a constant hum, that is a little anoying on long drives. The whine drives my wife completely nuts!
Re: Fixing past mistakes sucks! [Re: CUDAJAS] #953330
03/18/11 11:58 PM
03/18/11 11:58 PM
Can't have that. Might mount it on a square piece of soft(er) rubber. Make sure the mounting bolt thru the rubber does not contact metal/spray it w some kind of insulating material/get a stereo & play her favs
Re: Fixing past mistakes sucks! [Re: RapidRobert] #953331
03/19/11 12:23 AM
03/19/11 12:23 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I run an Aeromotive A1000 and used rubber mounts for it. It's mounted to the fuel tank you can see just under the floor...have Hushmat on the inside of the trunk area above it, and it's barely noticeable inside the car. (And I don't have a super loud exhaust either)
Re: Fixing past mistakes sucks! [Re: CUDAJAS] #953332
03/19/11 01:01 AM
03/19/11 01:01 AM
Northwest
Four40mopar Offline
Four40mopar  Offline
Northwest
I had a holley blue pump a while back and the same problem. I found a mounting set up on a 70's or 80's Nissan 280ZX at the junk yard. The holley pump fit perfect and it really cut the noise. It also makes a difference if you mount it to the floor pan or something more solid.
Re: Fixing past mistakes sucks! [Re: Four40mopar] #953333
03/19/11 08:53 AM
03/19/11 08:53 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
one word, FLOWMASTERS
Re: Fixing past mistakes sucks! [Re: bonefish] #953334
03/19/11 09:10 AM
03/19/11 09:10 AM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
From your headline, I thought you were referring to receiving a letter from a Child Support office.
Re: Fixing past mistakes sucks! - update [Re: Mr. T] #953335
03/27/11 04:33 PM
03/27/11 04:33 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Well, spent some time in the garage today pullign the water pump and timign cover off my 360.
Although it took a buch of time, it looks like it was the right call!
I found the fuel pump eccentric was worn badly, just like I expected, and it does not look like the hollow bolt is in the right spot. We at least the oil sliger was on there!
Here are some pics.
Well I have it all apart and will clean up the front of the engine and repaint the timign cover and water pump.
In all honesty, I really enjoyed beign out there workign away. Except that part where I realized what a poor mechanic I was in the past, I don't think any more that a quarter of the bolts I took out had any washers on them!!!!
Jason
Re: Fixing past mistakes sucks! - update [Re: CUDAJAS] #953336
03/27/11 04:34 PM
03/27/11 04:34 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
pic 2
Re: Fixing past mistakes sucks! - update [Re: CUDAJAS] #953337
03/27/11 04:35 PM
03/27/11 04:35 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
pic 3
Re: Fixing past mistakes sucks! - update [Re: CUDAJAS] #953338
03/27/11 10:51 PM
03/27/11 10:51 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Oh, wait...looks like the hollow bolt IS in the right spot (upper pass side corner)
Well...at least that is right!
Re: Fixing past mistakes sucks! - update [Re: CUDAJAS] #953339
03/27/11 11:20 PM
03/27/11 11:20 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
While you're fixing past mistakes how about fixing the color of that engine and K frame it's hurting my eyes....
Re: Fixing past mistakes sucks! - Update [Re: CUDAJAS] #953340
03/28/11 08:20 AM
03/28/11 08:20 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Now's a good time to degree in the camshaft.
And I'd chuck that electric pump in the trash, it's probably pretty wore out from cavation anyway.
Go back to a mechanicl pump and don't worry about noise and cavation(vapor lock) because I'd bet you don't have it plumbed right or with a large enough feed line. It's a street car right? and you want the wife to go with you sometimes? right?
Re: Fixing past mistakes sucks! - update [Re: CUDAJAS] #953341
03/28/11 09:34 AM
03/28/11 09:34 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
The lower bolt on the driver side is supposed to hold a duct, which also guides in the unused lower hole on the passenger side. This duct takes oil leak from the front cam bearing and pours it to the fuelpump side (behind the gear, but maybe this oil is splashed around and onto the fuelpump lever). Please check this. And, these bolts do not use washers. Locktite them, do the same with the cambolt.
My
Re: Fixing past mistakes sucks! - update [Re: screamindriver] #953342
03/28/11 11:22 PM
03/28/11 11:22 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
LOL...eventually I will repaint the K-frame...but the engine is staying purple!!!!
Re: Fixing past mistakes sucks! - Update [Re: Challenger 1] #953343
03/28/11 11:30 PM
03/28/11 11:30 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
I thought of that...But have never done it before, and do not have the tools. Can you degree a cam with the motor fully assembled???
I am hopefull that the mechanical pump will not have any vapour lock issue over the hot sumer months...but we will see. I may leave the electric pump hooked up just in case ( I have heard there are no issue runnign both) and only use it if need be.
Re: Fixing past mistakes sucks! - update [Re: Oyvind Mopar] #953344
03/28/11 11:33 PM
03/28/11 11:33 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
My
Hmmm I will look into the duct.
Yeah no washers on the thrust plate bolts...But I had very few washers on the timing cover bolts, probably shoudl be though.
