3speed wiper instalation help? #95311
07/27/08 07:50 AM
07/27/08 07:50 AM
Anonymous OP
Anonymous OP
i am fitting a 3speed wiper motor to replace the 2speed motor in my 1970 barracuda have tested the motor it workes fine have a 3speed switch P/N 2770380 have put in car turned ignition on grounded switch & motor but not working the 2speed motor and 2speed switch work fine but as soon as i put the 3speed motor & 3speed switch in it doesnt work anybodys help in this matter would be much appreciated cheers steve
Re: 3speed wiper instalation help? #95312
07/27/08 10:20 AM
07/27/08 10:20 AM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
There was an error in my original '67 Plymouth service manual showing the A-body wiring diagram. The wiring for the wipers going through the bulkhead connector were wrong.True,different year,different car but something to consider.
Re: 3speed wiper instalation help? [Re: bigslant6fan] #95313
07/27/08 11:50 AM
07/27/08 11:50 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think there is a wiring harness difference.
Re: 3speed wiper instalation help? [Re: stumpy] #95314
07/27/08 12:11 PM
07/27/08 12:11 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
it's not a plug in installation...if it was i would of done it also..the harness has extra wires for the 3spd...u must run those and the wiper transmission is different also..check a wiring diagraghm and add the extra wires...
Re: 3speed wiper instalation help? #95315
07/27/08 01:15 PM
07/27/08 01:15 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
The wiring is identical. Is the switch good? As stated above the transmission linkage is different.
Re: 3speed wiper instalation help? #95316
07/29/08 11:58 AM
07/29/08 11:58 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
3 speed switch needs to be grounded. IF you are testing the switch hanging out down the dash and still not mounted, run a ground wire to the switch
DON'T ASK HOW I KNOW
2 speed doesn't need ground
wiring is the same.
linkage is diff, at least main one and motor crank.
several years had diff linkage setup, some with nylon bushings some with retainers. Make sure you find the right main link and crank to your pivots and pivot link or a complete setup
Re: 3speed wiper instalation help? [Re: NachoRT74] #95317
08/04/08 06:16 AM
08/04/08 06:16 AM
Anonymous OP
Anonymous OP
thanks for the reply can i ground the switch from the body of the switch or where it contacts the metal where it screws in cheers steve ps or into the spare connector on switch
Re: 3speed wiper instalation help? #95318
08/04/08 02:26 PM
08/04/08 02:26 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
just tie a wire to same switch chassis... swicth gets the ground when is mounted throught the body
