Where to get/buy steel heater hose riser from Water P? #953067
03/18/11 11:07 AM
03/18/11 11:07 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
The steel tube riser that come out of the Water Pump housing, where can I buy a replacment? Should I just go to the plumbing section in lowes? Maybe get a Brass one?
(engine is a 70 440 w/ A/C)
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Where to get/buy steel heater hose riser from Water P? [Re: shanker] #953068
03/18/11 11:37 AM
03/18/11 11:37 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Where to get/buy steel heater hose riser from Water P? [Re: OzHemi] #953069
03/18/11 11:45 AM
03/18/11 11:45 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
thanks....I wonder if Orielly's, Autozone, or my local independent parts store would have these?
Re: Where to get/buy steel heater hose riser from Water P? [Re: shanker] #953070
03/18/11 02:12 PM
03/18/11 02:12 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
or a piece of water pipe.
Re: Where to get/buy steel heater hose riser from Water P? [Re: shanker] #953071
03/18/11 02:20 PM
03/18/11 02:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you don't mind them looking EXACTLY like originals you can get them in the HELP section.
