Clearance between rocker arm and pushrod cup
#952947
03/18/11 01:18 AM
03/18/11 01:18 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What is the minimum safe clearance between the pushrod cup and rocker arm?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Clearance between rocker arm and pushrod cup
[Re: 1_WILD_RT]
#952950
03/18/11 10:14 AM
03/18/11 10:14 AM
Von
NE Oklahoma
quote Typically the rule of thumb when measuring for pushrods is three threads showing on the adjuster screw then set your adjustable mock-up pushrod to length with valve clearance built in & use that measurement to order your pushrods...
Actually the # of threads showing is more or less minor....The number of threads isnt what is important, getting a straight shot of oil from the feed hole to the cup is IMO what is VERY important...In other words get the pushrod length correct to get a straight shot of oil to the cup and the # of threads falls as it may. The comment was told to me by a very respected builder on this site and he is dead nuts on...After fighting cup burning issues for a year and after mocking another motor, I see exactly why I was burning cups going with the 3 of threads showing rule of thumb.
Yes, I was asking about the clearance from cup to rocker body!
Thanx for the measurements, Im about .025 too long on my pushrod.
