Any Chrysler tech`s here? Help! #952884
03/17/11 11:22 PM
03/17/11 11:22 PM
N of Detroit
DaveDudek Offline OP
N of Detroit
Hey Guy`s, I have a 2002 Jeep Liberty and the "speed-O" stopped working, once in a while it will start working for a minute or two and then it will stop again? The check engine light comes on and the code reads P0500. I bought 2 vehicle speed sensors and replaced them both.. I still have the same problem.
Any idea`s?
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: Any Chrysler tech`s here? Help! [Re: DaveDudek] #952885
03/17/11 11:25 PM
03/17/11 11:25 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not a chrysler tech but I'd pull the gear cover & inspect the tone ring....
Re: Any Chrysler tech`s here? Help! [Re: DaveDudek] #952886
03/17/11 11:28 PM
03/17/11 11:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm not up on the jeep thing much. But ck to see if it has a speed sensor mounted on top of the rear diff. if so, and I think thats where it gets the vehicle speed signal from. chances are thats your problem, and pulling the rear diff cover is not bad idea to get all the junk out of it that usually contaminates the sensers
